Drag race zx10 2008 - Kawasaki ZX-10R.net
post #1 of 4 Old 03-25-2011, 09:24 PM Thread Starter
Drag race zx10 2008
well guys
i;m doing my zx10r 2008
for Drag race 1/8 mile
there is a guy in qatar who had 4.5 in Superstreet bikes in the 1/8 mile in GSXR1000
now i am building my bike for the next race in about 6 months
i will get the engine from Adamsperformance
but i have some questions
1- how much nitrous should i shot ? ( dry or wet ) ?
2- where can i get a light weight Swingram ? or are they the same ?
3- for shoting the nitrous can i use my bazzaz with the self map and tune it myself ? or i have to buy Motec or other ECU ?
4- rules say : All motorcycles in this class are restricted to a maximum wheel base of 64'' (+/- 10).
All motorcycles in this class are restricted to stock diameter wheels only. Cast wheels must
have 180 mm or greater tire width. No car tires
where can i get this stuff from ? wheel ? swingram tire ???
hope i get the answer
bike is already equiped with :
piston 13.5
head ported
cams ( webcams for high compression engine )
Sidewinder exhust system ( brocks )
Lower Kit adjustable
bazzaz + self map + map switch + traction control
mmm another question ,, will the traction help me in the dragrace ?
where can i get the AIR PUMP shifter to shif in hand ?
hope i get the answeer
abdullah is offline
post #2 of 4 Old 03-25-2011, 10:05 PM
sweetride10r's Avatar
if adams performance has your motor give them a call they will hook you up
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #3 of 4 Old 03-25-2011, 10:12 PM
lil ninja's Avatar
Send a message via MSN to lil ninja
you can use a dry shot but you will need to have a good fuel setup, injectors and fuel pump and your compression ratio will limit how much you can use safely.
adams performance,mcintosh machine are some good options
you should be able to use the bazzaz to tune for the nos
so your max wheelbase is 64" so an + 8" over swingarm will get you close and within the rules, use the stock wheels and maybe a small flat slick tyre ?? you get tyres and swingarm from adams performance. the traction control can be helpful and the airshifter you can also get from adams performance.
EVEN DA SMALLEST NINJA CAN KILL
a girl once told me " long and thin too far in, short and thick does the trick"....
lil ninja is offline
post #4 of 4 Old 03-26-2011, 05:35 PM Thread Starter
thanks boss :D
abdullah is offline
2008 zx10 Track/Race bike LOTS of upgrades! GosuPaintballer Bikes 4 Sale 18 07-06-2011 11:37 AM
Looking for a drag race step seat for my 06 zx10 stretched10R Strip 5 07-22-2010 11:15 AM
HOT ! 2008 ZX10 Competition Werkes Slip-On Race Exhaust Vonstallin The ZX-10R 7 03-05-2009 08:45 AM
2008 ZX10 Race body ? roadracer98 Race and Stunt 1 12-03-2008 09:55 PM
Drag Race!!! 06BLK10 Race and Stunt 12 10-12-2006 03:18 PM
