Busted My Oil Pan - Kawasaki ZX-10R.net
post #1 of 9 Old 05-25-2006, 04:29 PM Thread Starter
BANNED
Busted My Oil Pan
went to the track sunday. i changed maps earlier in the week and couldnt get better than a 9.7 on my 10. i tried to load the map i usually ran (a best of 9.4) but it wouldnt send it to my bike. it kept giving me an error. it would load other maps but not the one i usually ran. dindt make sense. i loaded other maps and still couldnt get my e.ts down past a 9.7. for some reason the bike wouldnt leave half as hard as with the usual map. i cut a best of 1.66 60 ft compared to my uaual low 1.5. so i finally started with a blank map and put in some numbers and compared it with my "fast map" and got it close and finally it sent. i got up to the line and not thinking about how i had been leaving that day, left at around 7-8k and the bike shot straight up. i usually ride it out way past the 60ft but it came up so fast that i completely let out........came down so hard i cracked my oil pan and oil went everywhere. so i am gonna have to order a new oil pan. isnt all that bad either $120.00 from kawi.........................that sux though
mikebar4 is offline
post #2 of 9 Old 05-25-2006, 08:24 PM
Ruthless Racing's Avatar
Images: 9
That sux dude, maybe you should raise her up a tad. Hope everything works out for you.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #3 of 9 Old 05-25-2006, 09:04 PM
TC24's Avatar
If you know a good welder you can cut the whole rear corner off and re-weld it flat to give a little more cleance.
'05 ZX-10R
'09 Streetglide
TC24 is offline
post #4 of 9 Old 05-25-2006, 09:34 PM Thread Starter
BANNED
havent thought about cutting it. i have thought about trying to put some sort of skid plate under it. not sure how it will work though. i usually dont come down that hard though. i was strapped down too, i know that didnt help any. at my last race, i noticed a busa and an r1 that had a full threaded stud through their front axle with about 15lbs of weights on front. but in my opinion, i think that would scare someone off if your wanting to put money on a race.
mikebar4 is offline
post #5 of 9 Old 05-25-2006, 09:44 PM
TC24's Avatar
You can strapp a lead weight to your headers, and do a pretty good job of hiding them, been thinking of it my self. I cracked my pan the other day and just got it welded for $10, did a great job too!
'05 ZX-10R
'09 Streetglide
TC24 is offline
post #6 of 9 Old 05-26-2006, 12:22 PM
BANNED
trikchop's Avatar
are you in central florida?? ill fixx it for you for free if you come by my shop tonight. ive cracked mine a few times.
trikchop is offline
post #7 of 9 Old 05-26-2006, 03:15 PM
Images: 9
The only downside with the threaded rod with weight through the front wheel is if it ever tank slaps it is going to be real severe. Something to think about. But yes it will allow you to launch harder and keep the front wheel down.
Kenny Poppell
Special Thanks:
Performance Psycle
Richies Tires
post #8 of 9 Old 05-26-2006, 04:57 PM Thread Starter
BANNED
i thought about getting it welded but i think its busted around the threads where the plug goes. i know they could weld it then tap it but i found one one ebay and im trying to get it from him. kawi takes forever on shipping something.
mikebar4 is offline
post #9 of 9 Old 05-26-2006, 05:59 PM
NATOR's Avatar
Cracky, thats crazy!!!! I mean that literally.
BIKES IS GOOD.
NATOR is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
Bad luck:( busted oil pan and lowers... XeUz The ZX-10R 21 11-07-2005 07:55 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
