Break fluid on tirre - Kawasaki ZX-10R.net
post #1 of 10 Old 05-04-2009, 11:49 AM Thread Starter
I was replacing my brakes lines and the Galper steel braided line leaked at the caliper. In short my NEW! Front Dunlop slick sat in brake fluid for about 2 days. I had the front tire off the stand and on the ground on the matt and did not see the fluid until I moved the bike a couple of days later.
How bad is brake fluid on a tire? Is this tire toast?????
I am doing a track day Saturday and will be nervous about using this tire. Anyone have this happen to them?
The fluid appears to have soaked into the tire.
FREAKING Galper! pisses me off. The banjo coupling at the caliper had a casting flaw that would not allow it to seal properly and all the brake fluid leaked out over night.
CSZX10R is offline
post #2 of 10 Old 05-04-2009, 11:53 AM
MIdlife PIMP
bodymanruss518's Avatar
Images: 12
Send a message via Yahoo to bodymanruss518
i wouldnt trust it,.......especially being a front tire!....but thats just me!
Better to have a gun and not need one, than to need a gun and not have one!!.......
you can lose money chasing women, but,......
you'll never lose women chasing money!!....
bodymanruss518 is offline
post #3 of 10 Old 05-04-2009, 12:02 PM
russell's Avatar
fuuuck that. replace it, quick!
That is the Curse of Speed which has plagued me all my life. I am a slave to it. On my tombstone they will carve, "IT NEVER GOT FAST ENOUGH FOR ME."
-Hunter S. Thompson
russell is offline
post #4 of 10 Old 05-04-2009, 12:06 PM
Dont use it.
breake fluid has this wonderfull ability to penetrate and soak into materials
if u get the fluid on the breake pads u will be able to whipe it away but if u heat the breake pad after u have whiped it u will see that the fluids have gotten into the material and it's near impossible to get it all out
i suspect that same thing will happen to you'r front wheel whipe it down get some heat into it and presto u will have a wet spot on the tire
i was so lucky myself to knock over some breake fluid without notising it giving both tires a good lube bath for a day both tires got trached the next day after some
_______________________________________
Black 2007 zx10r full akra system. pcIII .gipro
black 2000 tl1000r R.I.P
black 1992 ZXR 750 sold
black 1991 frz 600 sold
black 1972 cb750 with turbo R.I.P (boom)
Nickzx10 is offline
post #5 of 10 Old 05-04-2009, 12:08 PM
gumby092778's Avatar
Send a message via Yahoo to gumby092778
proven fact brake fluid will eat just about any thing it gets on i would not trust it
07zx10r se with parts and stuff
gumby092778 is offline
post #6 of 10 Old 05-04-2009, 09:15 PM
rocketracermike's Avatar
Originally Posted by Nickzx10 View Post
Dont use it.
replace them.
rocketracermike is offline
post #7 of 10 Old 05-04-2009, 11:57 PM Thread Starter
Thanks guys its gone! Sucks to toss a $200 tire because Galper produced a faulty product..... but better to be safe than sorry. This faulty break line has been one costly pain in the ass!!!!!!!! I think I will try to run goodrich just to get away from Galper.
And get this they want to charge me to send me a new brake line!!!!!!! I should send them a bill for my new tire!!!!!!!!!!!!!!!!!!!!!!
The even more bummer is to find a new matching Dunlop slick for my track day at Fontana this Saturday! I hate having to rush or miss sessions to replace tires. And at $270 a track day I want as much track time as possbile.
CSZX10R is offline
post #8 of 10 Old 05-05-2009, 12:25 AM
Send a message via Yahoo to wildcats
:iamwithst:iamwithst:iamwithst
If practice makes perfect, but no one is perfect so why try?
wildcats is offline
post #9 of 10 Old 05-05-2009, 12:31 AM
OrangeShirtDude's Avatar
Images: 21
Guys, brake fluid doesn't eat the internals of... the brake system. You know that bladder that sits underneath the reservoir cap? That's rubber. I'm going to suggest that the tire is probably ok. However, I can't guarantee it. Have you washed the spot really well with dish soap or other strong detergent? Then you can look to see if there is any discoloration. Maybe you can take it out and run it easy for a little while and then check it again.
Call the tire manufacturer. They should know what chemicals the compounds are sensitive to.
I got nothing
OrangeShirtDude is offline
post #10 of 10 Old 05-05-2009, 09:17 AM
bird_dog0347's Avatar
Images: 11
Call them, don't just trash it without at least KNOWING FOR SURE if it is ruined. I mean there are smart guys here on this forum, but the truth is no one here knows for sure.
04 10R - My late brother's bike, will keep forever
03 636 - Track bike build in progress
92 Foxbody coupe, 5.0, 5spd.
FASTEST CHICKEN IN THE SOUTH!
bird_dog0347 is offline
Brake fluid BDB10R Performance and Tech 5 03-29-2008 10:53 AM
Brake fluid Gang Green Performance and Tech 3 11-12-2007 10:26 AM
Lines And Fluid yamadak13 The Out House 0 05-01-2006 06:31 PM
Brake fluid NWZX10 Performance and Tech 6 01-24-2005 03:53 AM
Brake Fluid?? nolaZX10 The ZX-10R 15 09-08-2004 08:35 PM
