Braking - Kawasaki ZX-10R.net
post #1 of 14 Old 05-14-2006, 02:52 PM Thread Starter
socal's Avatar
Braking
Using both legs to squeeze the tank under hard braking reduces upper body fatigue and helps with the succeding down shifting. However, I rarely see the pros doing it. They always seem to have one knee out far in advance of the turn. Any insight??
WSMC #644
socal is offline
post #2 of 14 Old 05-14-2006, 05:25 PM
BANNED
Abortions Suck's Avatar
i think the 'squeeze the tank' bit sounds like a bit of advice from someone's book, twist of the wrist or the like. i think thats more advice given in 'riding for dummies,' mentality. a horrible habit to get into while under braking is sitting too far back in the seat..once you brake you slide forward on the seat, abruptly hit the tank, and unsettle the suspension under braking.
so i think squeezing the tank is just to get riders out of the habit of sitting back on the seat, and letting the suspension work more smoothly, and thus more quickly. obviously pro's have got it figured out, and do it properly without the mental note, thus they setup however they're comfortable going into the corner and rest up against the tank before hand.
Abortions Suck is offline
post #3 of 14 Old 05-15-2006, 11:06 AM
Archille's Avatar
AS, whoever told you that explanation exaggerated a bit. During hardbraking, there is weight transfer toward the front. If you can keep your weight toward the back, you gain braking force and stability.
But really, it's about braking technique. The Pros brake late and hard but they are so smooth at it. Most importantly, they trail-brake quite a bit toward the apex, scrubbing off speed all the way in while the straight up-n-down brakers still gathering up their pushing frontend. They get on and off the brake in such smoothness they don't need to knee-grip the tank but still brake harder than most. While this applies to most turns, special turns such as Shanghai's T1 where you go from 6 gear down to 1st...
"Every mistake is a learning opportunity"
http://wera.com/racerprofiles/David_Nguyen_18619.htm
Archille is offline
post #4 of 14 Old 05-15-2006, 11:23 AM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
I think the key is to keep all the weight on your pegs...IE, no weight on the bars...thats the idea...
James 3:7,8
hillcountry10r is offline
post #5 of 14 Old 05-15-2006, 11:52 AM
BANNED
exactly, to keep from adding inputs to the clipons/front suspension.
post #6 of 14 Old 05-15-2006, 11:56 AM
Archille's Avatar
Actually, Hill, the idea is not to let your weight shift around too much. (You can't keep your weight on the peg under braking. If you are not bracing yourself against the pegs, how can you keep yourself from moving forward under braking, let alone weighting the pegs. Remember, the pegs are in a neutral position from a leverage standpoint. Don't tell me you forgot your Physics 101 materials already. ) Thru braking technique, you can eliminate most of the weight transfer. I also use my outside inner leg portion against the tank to brace myself while I set up for the apex (ie., hanging off with knee out).
Archille is offline
post #7 of 14 Old 05-15-2006, 12:03 PM
Hillbillie Mod
Images: 31
Originally Posted by Archille
Actually, Hill, the idea is not to let your weight shift around too much. (You can't keep your weight on the peg under braking.) Thru braking technique, you can eliminate most of the weight transfer. I also use my outside inner leg portion against the tank to brace myself while I set up for the apex.
Can you explain that better please...I got lost somewhere after the "(" mark...
James 3:7,8
post #8 of 14 Old 05-15-2006, 12:07 PM
Archille's Avatar
Sorry, Hill, while you posted I went back and amended my post above.
Archille is offline
post #9 of 14 Old 05-15-2006, 12:07 PM
Green Hippie
treyzx10r's Avatar
that and these guys are in top physical condition as we would all be to if we raced for a living
VAE VICTUS!
treyzx10r is offline
post #10 of 14 Old 05-15-2006, 12:07 PM
Green Hippie
treyzx10r's Avatar
:headshake watta Hick
VAE VICTUS!
Hard Braking clunk? yamadak13 The ZX-10R 12 05-17-2006 06:27 PM
braking in tips SOUN1 The ZX-10R 19 04-25-2006 11:20 AM
forearm pain while braking Mustard The Out House 17 04-20-2006 08:43 PM
braking upgrade Lyzic Performance and Tech 12 04-03-2005 04:36 PM
Are you satisfy with the current braking system? Alex31 The ZX-10R 83 12-10-2004 11:06 AM
