2005 zx10r how to wheelie - Page 3 - Kawasaki ZX-10R.net
 31Likes
post #21 of 32 Old 10-17-2018, 09:33 AM
mbarnett's Avatar
I am in the same boat, i only ride on the streets and this is my second sportbike, and have never wheelied, i am trying to take advantage of every small bump in the road and come on to the throttle and i can feel the lack of friction under the front wheel, with the amount of power the zx10r has and this is without compressing the front end. This is just power at about 7-8 thousand in first or second.
The more i become comfortable with how it feels the better.
mbarnett is offline
post #22 of 32 Old 10-17-2018, 10:39 AM
ddipaola's Avatar
1. First gear, 35mph.
2. Clutch in.
3. At the same time rev AND hold at 8-9K RPMs.
4. Dump clutch.
5. Rear break if you're scared.
6. Gradually apply more/less throttle in the air as you advance and go further.
7. I like to accelerate as I come down. This will prevent premature fork seal damage and tank slaps when the front wheel hits. Don't slam dunk the wheel lol.
This action should be performed in under a second realistically. It should be nearly as fast as rev-matching a downshift. It will take some practice. Some people can wheelie at 6K RPMs and others at 10K. It's all about finding what best fits you seating position, weight, and speed. Pulling on the bars can sometimes help with getting started but I find it distracting. Having one less thing to worry about can turn a bad unsafe wheelie in a decent looking safer one.
When in doubt... send it!
ddipaola is offline
post #23 of 32 Old 10-17-2018, 11:04 AM
I agree with ddipaola except for pulling on bars. This could cause you to pull to hard on one side and bike won't be straight causing tank slap on land or worse... Your bike has more then enough HP to get the front off ground without pulling. Arms should be relaxed and definitely keep rear brake covered! You should actually practice with baby wheelies and then grab rear brake so your familiar with the action in case of a quick and high wheelie your not ready for. I find it easier to wheelie using left rear passenger peg and stand up. Helps get weight to rear of bike allowing for less RPMS. Take your time and before you know it, you will be riding on one wheel into the sunset!
Also, invest in a steering damper if you don't already have one. That bike is notorious for headshake!
Melampus likes this.
wheelz96 is offline
post #24 of 32 Old 01-28-2019, 12:47 AM
BAKWHEELTANGO's Avatar
mmmm wheelies.
here's one of mine a buddy caught. I would have ridden it further if I knew he was filming. Doh!
https://coub.com/view/1kdfqp
3rd gear clutch up @ 105mph ridden out to 145mph
(closed course, actually wasn't me - don't tell my mom)
KNEE DOWN - WHEEL UP
BAKWHEELTANGO is offline
post #25 of 32 Old 01-28-2019, 11:45 AM
michael4012's Avatar
Originally Posted by BAKWHEELTANGO View Post
mmmm wheelies.
I knew straight away that wasn't you......Coz it was me .....
BAKWHEELTANGO likes this.
michael4012 is offline
post #26 of 32 Old 01-29-2019, 11:37 PM
nakedinseattle's Avatar
it's all about that Yut Ugh
JayBoCC2 likes this.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #27 of 32 Old 01-31-2019, 10:05 AM
GreenWeenie's Avatar
Twist the throttle
evilaugust likes this.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #28 of 32 Old 05-03-2019, 02:20 AM
Innovate803's Avatar
Pin it down low in 2nd and around 9k she will come up.
Innovate803 is offline
post #29 of 32 Old 06-21-2019, 05:47 AM
If it's anything like my ninja 250 you have to slow to a crawl, get to about 10,000 rpm and then drop the clutch. Good luck.
wyrda is offline
post #30 of 32 Old 06-21-2019, 11:51 AM
make sure it's being recorded on video when you do that as well
Shut up and ride.
Wheelie ZX10R & R1 Prodemo Pictures and Videos 1 09-25-2017 01:35 PM
ZX10r Wheelie Bigeclipse The ZX-10R 142 05-02-2017 07:43 PM
Gen 3: zx10r wheelie question Bigeclipse The ZX-10R 53 01-22-2013 10:00 PM
Longest ZX10R wheelie I ever seen kawasaki123 The ZX-10R 68 04-09-2012 08:46 AM
How not to wheelie on a zx10r? Tailgunner The ZX-10R 28 01-25-2008 09:43 PM
