189 MPH??? - Kawasaki ZX-10R.net
post #1 of 14 Old 08-22-2004, 07:31 PM Thread Starter
189 MPH???
I HAVE 16 T FRONT SPROCKET.. RACING MY FRIEND ON HIS 929 ACCELERATION WAS VERY QUICK ON THE 10R .. AT ONE POINT SAW 189 ON THE SPEEDOMETER... I KNOW THAT THIS WASNT THE TRUE SPEED... BEING AS THOUGH I HAD THE 16T.. CAN ANYONE TELL ME WHAT THE ESTIMATED SPEED REALLY WAS.. ID APPRECIATE IT
black10r_n_nc is offline
post #2 of 14 Old 08-22-2004, 08:16 PM
Images: 7
I would estimate around 170. I also have the 16T and a speedohealer and get 4500 @ 60mph. If you were at redline then that would be about right.
Ground Zero is offline
post #3 of 14 Old 08-22-2004, 10:22 PM
MIA Post Whore
miykl's Avatar
~12-13% correction.
miykl is offline
post #4 of 14 Old 08-22-2004, 10:33 PM
Originally Posted by miykl
~12-13% correction.
I'm at -12.4% (GPS checked) with a 16t.
kwantam is offline
post #5 of 14 Old 08-23-2004, 03:40 AM
Send a message via AIM to gladding24
with new D218 on the rear, and a 16T on the front, 12,800 rpm in 6th should be 188mph actual, not indicated. 189 indicated-12.4%(correction)=is only 166 mph. 166MPH actual with a 16T should be about 11,300rpm.
Not sure what you were turning for revs though.
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #6 of 14 Old 08-23-2004, 04:57 AM
Actually, with a 190/50 tire (77.25" circumfrence) 16/39 geraring at 12800rpm would be 182.676mph under ideal conditions without areo drag and tire slip.
At 12800 engine rpm in 6th gear, the front sprocket is turning 6093 rpm.
12800 / 1.611(primary reduction ratio) / 1.304(6th gear ratio) = 6093.0794(front sprocket rpm)
6093.0794 / 2.44 (final drive ratio of 16/39) = 2497.1636(rear wheel rpm)
2497.1636 * 77.25"(tire circumfrence) = 192905.8881(inches)
192905.8881" / 12(1 foot)= 16075.490675(feet per minute)
16075.490675' * 60(minutes) = 964529.4405'(feet per hour)
964529.4405' / 5280(feet per mile ) = 182.676 mph
I have measured my rear tire with a stagger tape to get the size of 77.25"
I have tried different gearing and have radar'd my zx10r each time, and 1 tooth in the rear equals about 1.5 mph difference. Going down 1 tooth in front is like going up 2 7/16ths in the rear. The best speed I could get out of mine in 3/4 mile was 178mph with the stock gearing(17/39). The best I could get out of it with a 16/39 was 174mph. I have 17/41 on it now and get 176mph. It seems the error from theoretical speed and real speed is about 6%. The same 6% as the speedo error with the stock gearing. my speedo healer seting with 17/41 is -13%, and its within 1 mph at top speed.
I have come to believe that the tach may also have error.
Sorry for getting technical, but I had to back up my answer with the figures so i don't get flamed or told to STFU. [smilie=B:
Tom T is offline
post #7 of 14 Old 08-23-2004, 07:59 AM
prebancolt's Avatar
Re: 189 MPH???
About 167. My speedohealer required -13.2% correction when I went to the 16T in front. -13.2% correction from 189 is 167.
Gotta Love ORANGE!
prebancolt is offline
post #8 of 14 Old 08-23-2004, 01:45 PM
ummmmm WOW i believe you :D
scottymizt is offline
post #9 of 14 Old 08-23-2004, 04:39 PM
Damn look at the big brain on Tom, I beleive you :D
Frankyoz is offline
post #10 of 14 Old 08-23-2004, 06:20 PM
Thanks for the math Tom, I've been using someone else's gearing spreadsheet, and wasn't sure if it was 100% accurate, but I knew it was pretty close. I think our differences come from tire circumfrence. My calcs use 641.5MM diameter*3.14159=2015.33mm Circ.
2015.33mm / 10= 201.35CM
201.35cm /2.54= 79.27in. circ. of the tire.
This is where we differ, by about 2".
Stop Whining!!!
200 MPH 10R TAZ The ZX-10R 21 05-15-2004 11:50 PM
MCN big four review Eubank The ZX-10R 32 03-04-2004 05:03 PM
KAWABUNGA!!! Scott_in_FL The ZX-10R 34 02-01-2004 03:42 AM
First 04 shoot out at daytona. CDRacingZX6R Archives 20 12-11-2003 03:32 AM
