Gen 5: 2016- Gen 4 front wheel to Gen 5 kit - Page 4 - Kawasaki ZX-10R.net
 3Likes
post #31 of 44 Old 04-01-2019, 11:02 AM
To be clear, the gen 4 rear wheel is a direct bolt on without any spacers? I understand the front wheel needs different spacing. I am looking for a spare rear and found a couple complete gen 4 rear wheels with rotor and wanted to know if any other spacing is required.
Basically can I put a gen 4 stock rear wheel with gen 4 rotor on my gen 5 without any changes?
wheelz96 is offline
post #32 of 44 Old 04-01-2019, 08:17 PM
gen4GTO's Avatar
Gen4 and gen5 complete rear wheel and spacers are the same.
gen4GTO is offline
post #33 of 44 Old 04-02-2019, 07:02 AM
Thank you! The gen 4 rotor is different then gen 5 but does that matter? I would like a complete rear with rotor for quick changes at track.
wheelz96 is offline
post #34 of 44 Old 04-02-2019, 08:59 AM
mpp12's Avatar
RR rotors and R gen5 are diferent....
mpp12 is offline
post #35 of 44 Old 04-02-2019, 09:19 AM
If O.D. of rotor is same it will not be a problem. All I need to know is if the rotor O.D. is the same between gen 4 and gen 5. I can see it's a different shape but only concerned about diameter.
I was unaware the RR uses a different rotor from the R but that is irrelevant for what I am trying to do. I just want to make sure the gen 4 complete rear wheel w/rotor is compatible.
wheelz96 is offline
post #36 of 44 Old 04-02-2019, 01:28 PM
Gen4 and Gen5 rear wheels are the same, rotors are different shape but the OD is the same so in effect the rear wheels are interchangeable between both gens.
Fronts rotors are not the same at all. Gen5 is 330 OD and Gen4 is 310. Moreover, Gen5 RR is 330 OD but the carrier is dished (because of Marchesini rims) while R is 330 but carrier is flat.
mpp12 and wheelz96 like this.
Lanister is offline
post #37 of 44 Old 04-02-2019, 01:30 PM
Just ordered a complete gen4 rear wheel.. Will update if I find anything that does not directly fit.
wheelz96 is offline
post #38 of 44 Old 04-02-2019, 01:34 PM
I overlooked this but thanks for the info! Exactly what I was trying to figure out!
Do you know anyone else that makes a spacer kit for front wheel (gen4 to gen5)? OP is no longer making them... Certainly a cheaper route finding gen 4 wheels! I paid less than half of what a gen 5 rear complete is going for!
mpp12 likes this.
wheelz96 is offline
post #39 of 44 Old 04-03-2019, 04:49 PM
I have a set of brake rotor spacers that would convert gen4 wheel to fit gen5. PM me if you're interested.
Lanister is offline
post #40 of 44 Old 06-28-2019, 03:18 PM
GreenWeenie's Avatar
Thread resurrection... Has anyone tried the RR brake rotors on the Gen4 wheels, since they have a carrier that spaces the discs outward?
The spacing on the RR rotors looks about what you are getting from the above spacers.....
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
Gen 3 front wheel w/ rotors - (or gen 4) GODSPEED Parts, Gear and Accessories 2 01-15-2015 07:34 PM
Gen 2: tank fairings and rear wheel bearing kit TheBullRoars Parts, Gear and Accessories 3 05-26-2014 12:38 PM
For Sale: Gen 2 & Gen 3 Stock Front Wheel Rim 1fast10r619 Parts, Gear and Accessories 3 11-01-2012 09:33 AM
1st gen > 3rd gen Front Wheel Bearing Swap caboose Performance and Tech 26 07-31-2012 09:24 AM
Wanted: NEED GEN 2 or GEN 3 Front Wheel in Perfect shape JChi Wanted: Buy or Trade 7 06-23-2012 09:15 AM
