For Sale Full Race Bike Part Out (Gen3). Tons of parts! - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By BGoodwin22
post #1 of 7 Old 08-16-2019, 05:47 AM Thread Starter
BGoodwin22's Avatar
LIST/PRICES UPDATED 9/16!
Decided to hang up the leathers and get out of bike racing for a while, so I'm parting out my 2008 ZX-10r drag bike. Super clean with TONS of nice parts. Some brand new, some used. Some aftermarket, some stock. All prices include shipping in the lower 48 (except complete engine). Some prices are negotiable, especially when purchasing multiple items!
**Electrical/Electronics**
-Woolich Racing ECU tuning kit w. OEM ECU and relay box. Includes the USB module and harness to plug into factory wiring harness. $300.
-Gauge cluster/odometer. Under 5k miles, excellent condition. $180.
-Raptor LED single mode shift light. Amber shift light, includes mounting clips and lens covers. $50.
-Antigravity 12 Cell lightweight battery w. charger. P/N YT-12B, fits in stock battery location. Always maintained on charger during off-season and is currently reading just under 14V. $140.
-Stator generator w. side cover and rectifier. All in great condition. $175.
**Engine/Transmission Parts**
-Gen3 complete stock engine. It was a backup engine for when my built engine was down. 15,000 miles. Complete and ready to go from pan to coils. Just add a new filter and oil, hook up coolant hoses, electrical connections and throttle bodies and it is ready to run. $1000 + Freight.
-DME billet oil pan with pickup. Pan has been painted black and does have some paint chips due to debris off the front tire. Swinging pickup is updated design with less than 100 passes. $350.
-Cycle Concept billet oil cooler block off (Brand new, used for mockup only). $60.
-"Prostreet" undercut transmission cut by Robinson Industries with WWB ceramic bearings. This is the steeper angle cuts meant for drag racing only. Can reduce kill times to pretty much nothing on motor. Threads for clutch nut aren't perfect (some are partially missing from having to cut a nut off), but the clutch nut can still be installed and torqued without issues. Never seen power adders. $540.
-Robinson Industries low 1st gear (40T). Fits 2008-2015. (Brand new) $220.
-Air shifter setup. Complete custom plug and play for Gen3 ZX-10r. Includes air shifter with solenoid, extra air line, fittings, PMR stealth handlebar push button, Orient Express NextUp kill box and plug and play harness for Gen3 ZX-10r, and custom shifter mounting bracket. Bracket is CNC machined billet and allows the shifter to be mounted without drilling into your frame. $440.
-OEM ZX-10r radiator shortened by McIntosh Machine. Includes OEM fan adapted to work with the shortened radiator. No issues, works as it should. I also have stock coolant tank and hoses if you need them. $150.
-OEM air box w. BMC race air filter (like new), all short stacks, upper injectors, SMOG block-off plates, UNI crankcase breather (new) and all airbox holes capped. $80.
-Bored throttle bodies. 45mm bore done by MaxBore earlier this year, have not been ran since. Includes secondary throttle plates (not installed). Does not include injectors. $415.
-Cleaned/flowed upper and lower injector set. Work done by InjectorRx earlier this year, have not been ran since. Includes paperwork. $130.
-Kawasaki 0.55mm head gaskets, P/N 11004-0022 (2 total, Brand new in package). $45 ea.
-Cometic engine rebuild gasket set, P/N C8715 (Brand new in package). $40.
-Gen3 stock cylinder head. Complete minus camshafts and cam sensor. $300.
-Gen3 stock exhaust valves. Set of 8. Make an offer!
-Oil pan (2006-2010). $80.
-Pistons & connecting rods. Pistons are good, one rod spun a bearing. $40.
-Clutch cover. $75.
-Starter. $70.
-Clutch pressure plate, inner clutch hub, and puller shaft. $50.
**Engine parts from other ZX-10’s**
-Gen4 race intake cam. P/N 49118-0728. Brand new in package. $160.
-Gen4 stock intake & exhaust cams. Includes gears. $100 for the pair.
-Gen4 ignition coils (4). $40.
-Gen1 intake cam. No gear. Make an offer!
**Chassis/Body Parts**
-2008 frame. Clean and clear title, in hand. Less than 5000 miles on it. Never been wrecked or even dropped. Left side has a riv-nut installed to mount air shifter. Right side upper cylinder head/motor mount clearanced on inside for Gen4 head conversion, so it will work with Gen3 or Gen4 head. Will include gauge cluster/odometer. $1000 + shipping.
-McIntosh internally lowered and powdercoated black forks. 1” of travel to be compliant with most class rules. Forks are fresh, have not been ran since coming back from McIntosh. $450. Will sell as complete front suspension package with offset trees for $750.
-HRP ” offset lightweight triple trees w. steering stem. Black powdercoated with black aluminum bars. New, only used for mock-up. $400. Will sell as complete front suspension package with forks for $750.
-Front sprockets: 525 pitch, OEM 17T, OEM 16T, Driven 16T.
-Rear sprocket: 525 pitch, OEM 40T.
-PMR billet two button handlebar switch, p/n PM-57. Includes two black on-off pushbuttons, one black momentary pushbutton, and one illuminated red on-off pushbutton (Brand new) $75.
-Ohlins steering damper w. Kyle Racing race-spec valving. Includes OEM brackets. $120.
-Front fender lowering brackets. Includes hardware. $30.
-Armour Bodies race fairing set for Gen3 ZX-10's. P/N 74-0167SS. No broken mounts or repairs. Good condition, fit as they should. Includes one piece upper/sides, one piece belly pan w. fasteners, front fender, one piece tail, and undertail draft panel w. fasteners. $400.
-Lightened rear upper subframe. Works with race fairings only, eliminates everything except air and tip over sensor (now mounted to subframe directly).
-Catalyst drag step seat w. TechSpec pad. Painted PPG jet black base/clear. $100.
-Billet mirror block-off plates, painted PPG jet black w. clear. $25.
-LP smoke integrated taillight. Works as it should, lots of rubber to clean off for street riding.
-Zero Gravity smoke standard windscreen. New, only used for mockup.
-Puig double bubble smoke windscreen. Vinyl numbers can be removed. Good condition.
-Other aftermarket parts...Shogun frame sliders & swingarm spools, adjustable shorty levers, billet adjustable kickstand, Venhill black braided front brake lines, lightened brake bracket and low profile brake stop.
**Stock Gen3 ZX-10r Kawasaki parts**
-Complete lock set (2 keys, ignition switch, gas cap, and rear seat lock). $175.
-Rearsets w. heel plates (pair). Right includes brake lever and rear master cylinder. Left includes shift lever/linkage. Shift lever has a hole drilled through for air shifter mount. Brake lever modified underneath for sidewinder clearance. $125.
-Front brake calipers (pair). Black braided brake lines available as well. $50.
-Rear brake caliper w. bracket. $25.
-Front & rear seats. Great condition. Strap on passenger seat has a tiny nick in the vinyl. $50.
-Headlight. Lenses are smoked. No broken tabs or mounts. Have HIDs that can be included as well. $100.
-Misc. small parts are available as well...sprocket cover, ram air scoop, taillight, hand control levers, switch block & throttle cable housing, etc. Make an offer!!
OEM Kawasaki tank and plastics are painted PPG jet black base/clear:
-Gas tank. Never dropped or damaged. Inside is super clean. Does not include pump or gas cap. $350.
-Solo seat cowl. Good condition. $70.
-Plastics. Front fender, nose/air scoop, and upper side fairings (left & right) w. inner headlight covers and seat side covers are all in good condition with no broken mounts/tabs/etc. Small triangle engine side covers are good condition as well. Left side cover was cut for frame sliders. Can include frame sliders, if desired. $300.
Lower belly fairings are damaged from scraping the ground and are not available.
Undertail panel was smoothed and color matched. Lots of rubber to clean off, but otherwise in good condition.
Tail side fairings and center filler panel are in fair condition. Forward mount points for side fairings need to be reattached and center panel has some chafing marks from the drag seat.
ID:	423877   Click image for larger version
ID:	423879   Click image for larger version
ID:	423881   Click image for larger version
ID:	423883   Click image for larger version
ID:	424023   Click image for larger version
Guarf likes this.
BGoodwin22 is offline
post #2 of 7 Old 08-16-2019, 05:55 AM Thread Starter
BGoodwin22's Avatar
More pics
ID:	424005   Click image for larger version
ID:	424009   Click image for larger version
ID:	424011   Click image for larger version
ID:	424013   Click image for larger version
ID:	424017   Click image for larger version
Guarf likes this.
post #3 of 7 Old 08-21-2019, 09:28 AM Thread Starter
BGoodwin22's Avatar
More pics.
ID:	424029   Click image for larger version
ID:	424031   Click image for larger version
ID:	424033   Click image for larger version
ID:	424035   Click image for larger version
post #4 of 7 Old 08-24-2019, 04:21 PM Thread Starter
BGoodwin22's Avatar
Swingarm and rear suspension, sidewinder, tires, wheels and rotors are all sold.
post #5 of 7 Old 08-25-2019, 12:54 PM Thread Starter
BGoodwin22's Avatar
Cases, crank, bearings, clutch parts, and filters sold. List updated.
post #6 of 7 Old 08-26-2019, 11:13 AM
Pm inbound
hoppa2k6 is offline
post #7 of 7 Old 09-10-2019, 02:46 PM Thread Starter
BGoodwin22's Avatar
Bump!!
