LIST/PRICES UPDATED 10/22!
All prices include shipping in the lower 48 (except complete engine). Some prices are negotiable if purchasing multiple items to save on shipping. If the part is not listed below, then it is no longer available!
AFTERMARKET & PERFORMANCE PARTS
-McIntosh internally lowered and powdercoated black forks. 1” of travel. Forks are fresh, have not been ran since coming back from McIntosh. $425. Will sell as complete front suspension package with offset trees for $750.
-HRP ½” offset lightweight triple trees w. steering stem. Black powdercoated with black aluminum bars. New, only used for mock-up. $375. Will sell as complete front suspension package with forks for $750.
-Shortened radiator done by McIntosh. Includes OEM fan adapted to work with the shortened radiator. No issues, works as it should. I also have stock coolant tank and hoses if you need them. $150.
-Air box w. BMC race air filter (like new), all short intake stacks, upper injectors, SMOG block-off plates, UNI crankcase breather (new) and all airbox holes capped. $75.
-45mm overbore throttle bodies. Done by MaxBore this year and have not been ran since. Does not include injectors. $400.
-Cleaned/flowed upper and lower injector set. Work done by InjectorRx this year and have not been ran since. Includes paperwork. $125.
-Kawasaki 0.55mm head gaskets (2). P/N 11004-0022 (NEW). $45 ea.
-Cometic engine rebuild gasket set. P/N C8715 (NEW) $35.
-Woolich Racing ECU tuning kit w. OEM ECU and relay box. Incl. USB module and harness to plug into factory wiring. $300.
-Antigravity 12 Cell lightweight battery w. charger. P/N YT-12B, fits in stock battery location. Always maintained on charger during off-season and is currently reading just under 14V. $130.
-Billet front fender lowering brackets. Incl. hardware. $30.
-Billet mirror block-off plates, painted PPG jet black w. clear. $25.
-Armour Bodies race fairing set for Gen3 ZX-10's. P/N 74-0167SS. No broken mounts or repairs. Good condition, fit as they should. Incl. one piece upper/sides, one piece belly pan w. fasteners, front fender, one piece tail, and undertail draft panel w. fasteners. $400.
-Lightened rear upper subframe. Works with race fairings only, eliminates everything except air and tip over sensor (now mounted to subframe directly).
-Zero Gravity smoke standard windscreen. New, only used for mockup. $40.
-Puig double bubble smoke windscreen. Vinyl numbers can be removed. Good condition. $50.
-Driven 16T 525 front sprocket.
-Lightened brake bracket and low profile brake stop for extended swingarms.
STOCK OEM KAWASAKI PARTS
-2008 frame. Clean and clear title, in hand. Less than 5000 miles on it. Never been down. Left side has a riv-nut installed to mount air shifter. Right side upper cylinder head/motor mount clearanced on inside for Gen4 head conversion, so it will work with Gen3 or Gen4 head. $1000.
-Gen3 complete stock engine. Complete and ready to go from pan to coils. Just add oil, hook up hoses/electrical connections and it is ready to run. $900 + Freight.
-Headlight. Lenses are smoked. No broken tabs or mounts. Have HIDs that can be included as well. $90.
-Complete lock set (2 keys, ignition switch, gas cap, and rear seat lock). $160.
-Gauge cluster/odometer. Under 5k miles, excellent condition. $180.
-Stator generator w. side cover and rectifier. All in great condition. $160.
-Rearsets w. heel plates (pair). Right includes brake lever and rear master cylinder. Left includes shift lever/linkage. Shift lever has a hole drilled through for air shifter mount. Brake lever modified underneath for sidewinder clearance. $125.
-Front brake calipers (pair). Black braided brake lines available as well. $50.
-Rear brake caliper w. bracket. $25.
-Front & rear seats. Great condition. Strap on passenger seat has a tiny nick in the vinyl. $50.
-Gen3 stock cylinder head. Complete minus camshafts and cam sensor. $300.
-Gen3 stock exhaust valves. Set of 8. Make an offer!
-Oil pan (2006-2010). $75.
-Pistons & connecting rods. Pistons are good, one rod spun bearing. $40.
-Clutch cover. $75.
-Starter. $70.
-Clutch pressure plate, inner clutch hub, and puller shaft. $50.
-Front sprockets: 525 pitch, OEM 17T, OEM 16T.
-Rear sprocket: 525 pitch, OEM 40T.
-Misc. small parts are available as well...sprocket cover, ram air scoop, taillight, hand control levers, switch block & throttle cable housing, etc. Make an offer!!
Engine parts from other ZX-10’s
-Gen4 race intake cam. P/N 49118-0728. Brand new in package. $160.
-Gen4 stock intake & exhaust cams. Includes gears. $100 for the pair.
-Gen4 ignition coils (4). $40.
-Gen1 intake cam. No gear. Make an offer!
-Clutch cover. $75.
-Starter. $70.
