Wheelie help! - Kawasaki ZX-10R.net
post #1 of 46 Old 05-27-2007, 02:40 PM Thread Starter
Wheelie help!
everywhere i read about the 10r ppl say they can power wheelie all the way up to 3rd gear, stock. it just doesn't seem to happen for me. what am i doin wrong?
alphamage is offline
post #2 of 46 Old 05-27-2007, 02:49 PM
Im a 220lb guy and I havent tried in third but I can power her up in 1st & 2nd just by scootin my ass back on the seat, finding the right RPM, and busting it open.
Just make sure youre giving it the power it needs.
Gen 2
Galfer front & rear steel braided red brake lines, Nissin ZX14 calipers, Zero gravity smoked double bubble windscreen, Rifleman 1/5 throttle conversion, JP Racing shorty levers, Sato adjustable rear sets, K/N Air filter, Competition werkes GP exhaust, Vortex 16t/41t sprockets, EK 525 MVXZ 525 chain, Gen2 busa bodybuilder shock, Dunlop PP 2CT, Speedohealer v4, Power Commander V
jagleaso is offline
post #3 of 46 Old 05-27-2007, 03:18 PM Thread Starter
hmmm...im at 190 lbs guy and cant seem to get it off the ground in second. i'll try higher rpm and sitting farther back i guess.
post #4 of 46 Old 05-27-2007, 03:23 PM
Murphdog's Avatar
Where do you live? Im in Wyoming and in stock form my bike wouldnt power wheelie in any gear, the reason is the altitude, you loose a lot of power the higher you live, Im around 6500 feet.
05' Ti ZX-10R, Cut down Yoshi, PCIII, Rifelman 1/5 Throttle, GPR Damper, BMC Race Filter, Champ Frame Sliders,GIpro ATRE, Pazzo Short Levers, Sato Rearsets, Pilot Powers, Driven Chain and Sprockets 520 +1 Rear -1 Front, Nissen Front Master Cylinder, Galfer Braided brake lines, Changed gauge cluster to red, Hot bodies undetail, Flush mount turn signals, But best Mod of all TRACK DAYS and Classes
Murphdog is offline
post #5 of 46 Old 05-27-2007, 03:35 PM
Dragone's Avatar
Images: 11
hmm, I am in Reno so altitude may be a consideration. I needed to set up my suspension in order to keep the ride stable. 176lbs in gear.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #6 of 46 Old 05-27-2007, 03:35 PM
mattfr12's Avatar
Send a message via AIM to mattfr12
to power it up in second you gotta be making pretty good hp so your going to be going like 75mph and up thats how fast im going when i do it. just sit back on the seat open and close open your right up.
mattfr12 is offline
post #7 of 46 Old 05-27-2007, 03:45 PM
BANNED
ZX10Rracer's Avatar
why power when you can clutch it up????
ZX10Rracer is offline
post #8 of 46 Old 05-27-2007, 04:11 PM
TX-954's Avatar
I can power wheelie my buddies 04 when its at stock height in 3rd or 4th at about 110 with no trouble. Its lot easier though if you "bump" the clutch.
Oh yea, and I'm about 175-180lbs. in boxers.
TX-954 is offline
post #9 of 46 Old 05-27-2007, 04:12 PM
mattfr12's Avatar
i always clutch power is to slow. but then again i think my wheeling days are over just meeses your bike up in every way.
mattfr12 is offline
post #10 of 46 Old 05-27-2007, 05:35 PM
Post Whore
Frankyoz's Avatar
You gotta load your suspenion with shutting down the throttle for that split second before you power it back up. I have a 04 and I can power it up all the way through 3rd. Mess with your rpms a bit to find the torque you need but its there. I can get a bit of a hop in 4th but not enough to come more than maybe 1ft off the ground. Good luck, and expect to go through chains and rear tires at a rapid rate if you plan on powering them up.
Except for ending Slavery, Fascism, Nazism, and Communism WAR has never solved anything.
Frankyoz is offline
How not to do a wheelie..... Iridium The Out House 18 08-24-2006 09:56 PM
Wheelie Fun oz914 The Out House 10 04-19-2006 02:57 PM
150 MPH wheelie possible??? No-Mo Race and Stunt 26 04-14-2006 01:44 AM
Bad Wheelie Ghost Pictures and Videos 12 02-19-2006 12:38 PM
Can I do a wheelie? litrejunkie The ZX-10R 18 03-06-2005 03:05 PM
