Wheel/Tire Balancing? - Kawasaki ZX-10R.net
post #1 of 15 Old 05-01-2007, 03:22 PM Thread Starter
Who does it and who doesn't? I have heard both ways so just curious.
2004 10r Green
Power Commander, Sato rear sets, hyperpro steering damper, Muzzys carbon slip on, ss brake lines etc..
Fast10 is offline
post #2 of 15 Old 05-01-2007, 03:29 PM
MIA Ex-Mod
Tread70's Avatar
All wheels should at the very least be checked after a new tire is put on. Most tires I have found are virtually balanced from the factory and need little or no adjustment as long as the wheel is balanced. But always check them.
Tread70 is offline
post #3 of 15 Old 05-01-2007, 03:31 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
always balance them. Why not?
zx10ragentblack is offline
post #4 of 15 Old 05-01-2007, 03:38 PM
grover's Avatar
Send a message via AIM to grover
Some brands, like dunop, come with a yellow dot on the side of the tire. If you line that up with the air nozzle on the wheel it won't need balancing. I have always balanced mine when changing them. The rear is as big a deal but if the front is off you will get a bad vibration at higher speeds.
KRONREIF TRUNKENPOLZ MATTIGHOFEN
grover is offline
post #5 of 15 Old 05-01-2007, 03:41 PM
Yankee Racer
Images: 9
while you should always align them on the dot it does not mean that they will for sure be balanced correctly.
post #6 of 15 Old 05-01-2007, 03:43 PM
MIA Ex-Mod
Tread70's Avatar
Tread70 is offline
post #7 of 15 Old 05-01-2007, 04:13 PM
grover's Avatar
Yeah that's true. I still check them but i haven't found any off yet. Course i've only went through a few sets of the qualifiers so far.
grover is offline
post #8 of 15 Old 05-01-2007, 04:33 PM
Big Daddy's Avatar
Images: 38
very true and i've used other brands besides Funlops that have some sort of marking and lined it up with the valve stem and still required balancing with additional weight.
I static balance my own and have for some years now mainly because i feel i'll do a far superior job than any/most shops.
Big Daddy is offline
post #9 of 15 Old 05-01-2007, 04:45 PM
rocketracermike's Avatar
I'm going to buy a balancer, spoons, rim guards. The last time i took my wheels to the shop. they put the tire on backward. No more for me. Time to do it myself.
rocketracermike is offline
post #10 of 15 Old 05-01-2007, 04:52 PM
MIA Ex-Mod
Tread70's Avatar
You may want to check out http://www.nomartirechanger.com/
Tread70 is offline
Rear Wheel "Hop" with new rear Tire? Zixxer2Go Performance and Tech 5 09-12-2006 07:09 PM
I was told a 180/55 rear tire on a 6.0 inch wheel is bad... BrianRacerboy The Out House 9 05-12-2006 02:10 PM
Great machine for easy tire change and balancing lespaul66 The Out House 5 03-05-2006 07:39 PM
Tire Balancing??? OmegaX Performance and Tech 9 02-05-2006 11:13 PM
180/55 rear tire= wheel spin miykl The ZX-10R 6 08-11-2004 06:26 AM
