TV electronics gurus - Kawasaki ZX-10R.net
post #1 of 15 Old 11-06-2011, 09:44 AM Thread Starter
logmaster's Avatar
I have a sony sxrd 55" rear projection TV
got a little warning message that the projection lamp is due to be replaced ( picture seems fine, almost 4 years to the date we bought it........maybe just a fixed time warning thing?)
anyways, figure I'll get a replacement lamp to have on hand ( since it looks like the Packers will be in the Super Bowl again )
As I search online it appears there's a choice of bulb wattage one says 100-120 watt and a more expensive one says 150 watt
naturally, I'm inclined to get the highest wattage
is there any difference in picture quality with the higher wattage bulb or any other type of bulb that would be an upgrade?
logmaster is offline
post #2 of 15 Old 11-06-2011, 12:52 PM
Starbucks Connoisseur
Static IP's Avatar
Well here's how the lamps work on most rear Proj and DLP's.
They don't go slowly bad. They are good till the warning comes up and then you have limited time till it goes out. Like your reserv gas on your bike, the bike won't run any different when the gas light comes up, but that you have some time left till poof, it's dead.
As far as the wattage, I would ask Sony or a few qualified stores & online sited like B&Hphoto.com, etc. Sometimes the higher wattage can ruin what the circuit boards permit if it wasn't designed for that. 4-5 years is average for light use and 3 years for heavy use, like kids and family watching 5+ hours a day.
Here's a site you might want to join for TV folks:
http://www.avsforum.com
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
post #3 of 15 Old 11-06-2011, 01:04 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
:iamwithst....good post AND good info right there. i'd get the bulb asap though cause like Static said, after you get the warning then it's only a matter of time before the current bulb goes out.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #4 of 15 Old 11-06-2011, 04:57 PM Thread Starter
logmaster's Avatar
Will order a stock replacement tomorrow.
Thanks for the help guys
post #5 of 15 Old 11-06-2011, 07:57 PM
evallarta1's Avatar
Just a FYI, I had the same thing happen to me. The message came on so I bought a bulb to have on hand so once the bulb burned out I could swap it. A year and a half later Im still waiting to swap it out.
Velocity Calibrations
evallarta1 is offline
post #6 of 15 Old 11-06-2011, 08:14 PM
Static IP's Avatar
Better to have and wait then not to have and oops bulb just went out and now instead of a 5 minute wait to replace it, it's like a week or so.
13' Bagel
post #7 of 15 Old 11-06-2011, 11:03 PM
teedub21's Avatar
Sounds like a perfect time to get rid of the projection set and get a Plasma!
teedub21 is offline
post #8 of 15 Old 11-07-2011, 04:08 AM
vegasn1nja's Avatar
People still own projection tv's?
Carbon Akrapovic slip-on w/link pipe
Gutted headers
6000k HID's
PC V
vegasn1nja is offline
post #9 of 15 Old 11-07-2011, 04:43 AM
The Nam3less's Avatar
:iamwithst
'11 Black zx-10r | Tech-spec Tank pad | Akraprovic w/ link | Power Commander V | Auto tune | HID | 1/5 Insert | Driven Smog Plates | DMP integrated tail light | Vortex rear sets w/ new pressure switch | Puig dark smoke windscreen | BMC Air Filter | Cox Radiator Guard |
To Do List:
ECU reflash
Steering Damper revalved
The Nam3less is offline
post #10 of 15 Old 11-07-2011, 05:32 AM
or10r's Avatar
Nice post static. Always love to see members helpin each other out.
or10r is offline
2011 Zx10r...Electronics Excellent..Engine not much different.. 09zx10miami The ZX-10R 113 04-20-2015 08:39 AM
Scorpio Alarm question-who knows electronics? Sasquatch General Motorcycle Discussions 11 11-08-2010 06:00 PM
For Tech Gurus... lenshead Performance and Tech 14 07-24-2009 03:35 PM
Healtech Electronics X-TRE (Increases HP and removes speed limiter!) Calsportbike-Kim Vendors deals 7 09-05-2008 09:44 AM
Need Electronics Help...Relays casey The Out House 8 08-22-2007 06:07 PM
