Should I put lower gears in my truck? - Kawasaki ZX-10R.net
post #1 of 15 Old 03-01-2007, 04:59 PM Thread Starter
Brandon's Avatar
Send a message via AIM to Brandon
Ive got an 03 Ram, hemi 4dr 4wd blah blah blah. I love my truck, but the dipshits at Chrysler put 3:55 gears in the thing. I went from 17" rims up to the 20's and increased the tire size by a little over an inch.
I did about a 2 hour drive w/ it yesterday and it drove me nuts. we have a lot of rolling hills here and i basically took it out of overdrive because it was dogging so bad.
I want to put 4:10's in it. price should be around $1000 installed. Anyone care to input? w/ the price of fuel on the rise is it worth it (even though my mileage may be a bit better w/ the 4:10's or so i hear).
I tow a 6x12 enclosed trailer to the track and im dreading doing it this summer unless i do a gear swap.
Live it before its too late.
Brandon is offline
post #2 of 15 Old 03-01-2007, 05:48 PM
BrockLanders's Avatar
No.
But I have done a thousand dreadful things,
As willingly as one would kill a fly,
And nothing grieves me heartily indeed,
But that I cannot do ten thousand more.
-Titus Andronicus
NESBA #78
BrockLanders is offline
post #3 of 15 Old 03-01-2007, 05:50 PM
bugman53's Avatar
I would do 3.72's to keep the rpms down on the HW. 4.10's are a pretty low grear. Just my 2cent.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #4 of 15 Old 03-01-2007, 05:56 PM
Send a message via AIM to lesleybrownjr
Go back to the 17"rims that came on it.When you changed the tires you raised the gearing both front and aft.To correct it you would have to change the gearing in the rear and front case BOTH.Its not worth the price IMHO.But it you just have to have the 20"wheels do the front and rear gear swap.Ride safe....Les
lesleybrownjr is offline
post #5 of 15 Old 03-01-2007, 06:04 PM
Big Daddy's Avatar
Images: 38
Originally Posted by lesleybrownjr
Go back to the 17"rims that came on it. When you changed the tires you raised the gearing both front and aft. To correct it you would have to change the gearing in the rear and front case BOTH. Its not worth the price IMHO.But it you just have to have the 20"wheels do the front and rear gear swap. Ride safe....Les
yup the wheel & tire change did the deed not the 3:55's
Big Daddy is offline
post #6 of 15 Old 03-01-2007, 06:04 PM Thread Starter
Brandon's Avatar
I sold the 17" wheels. I put the 06 model 20's on it and they look a lot better, i also just dumped $$$ on decent tires.
Most of the trucks that came stock w/ the 20's came w/ 3:92's. From what Ive read on the dodge forums most guys say to go w/ 4:56's, but thats a bit low for my taste.
I drive 2 miles to work and back, so its not a necessity and it will pull the trailer, just takes a bit more work.
It was pretty gutless w/ the 17's on it. (unless your into it all the time) it shifts into overdrive way to early. Im not sure they even offer 3:55's in the 4dr 4wd anymore. I think they stopped after 03.
what about a superchips and adjusting the shifting points?
Brandon is offline
post #7 of 15 Old 03-01-2007, 06:17 PM
Supercharged Mod
One of those reprogrammers should be able to adjust the shift points to match the new tire size. I would think this will help with the hunting, but it's going to cost you mileage. The tall gearing and the early shifting into OD are designed to make fuel consumption less horrible.
I've towed with an automatic before. Never again, I hated it, constant shifting on anything that didn't even look like a hill. Last two vehicles have been diesel and manual transmission ... much better.
GoFaster is offline
post #8 of 15 Old 03-01-2007, 09:45 PM
BANNED
Bigcat#44's Avatar
I def think you should go to the 4:10s just for the ability to go bigger (tire size) if you wanted to. I have a Powerwagon that came stock with 4:56 and it's fine on both the highway and the normal city stuff. You will notice a difference in your gas mileage though.
Bigcat#44 is offline
post #9 of 15 Old 03-01-2007, 10:06 PM
norcal10's Avatar
a cheaper alternative might be to find 3.92 equipped axles at a wrecking yard, then selling yours. the rear is super easy to swap, the front is a little harder, but not bad. i did this with a jeep cherokee i had a while ago. check yur local wrecking yards, or even ebay, for used axles with the gears you are looking for. then you can make some of the cash back by selling yours.
norcal10 is offline
post #10 of 15 Old 03-01-2007, 10:15 PM
FXSTCHIEF's Avatar
Here...try this website and it will determine what you will require for what you want. http://www.csgnetwork.com/gearratcalc.html
2005 ZX-10R
2002 FXST CUSTOM
2001 KX 250
2003 CRF 450R (Sons)
2005 KXF 250F (Sons)
2005 KX 85
2003 XR50 (108cc)
2006 KLX 110 (Daughters)
FXSTCHIEF is offline
my clanky gears ^ JeredH Performance and Tech 7 08-12-2005 01:54 AM
One bad truck.Parish's truck. sabersaw30 Pictures and Videos 2 08-05-2005 09:16 PM
Cam Gears... Bobster Performance and Tech 2 04-14-2005 10:45 AM
This guy can shift some gears. sabersaw30 Pictures and Videos 1 04-07-2005 01:22 PM
chain and gears fbdr24 The ZX-10R 34 07-24-2004 04:09 AM
