shifting question - Kawasaki ZX-10R.net
post #1 of 11 Old 10-02-2005, 01:13 PM Thread Starter
shifting question
i would like to know your opinions on shifting gears, i usually always use the clutch because i can get the smoothest shifts that way, a couple of my friends that ride gsxr's say they clutchless shift and it's a lot smoother for them to do it that way. i notice when i clutchless shift, it isn't a smooth, and it is jerky, is this just me because im not used to shifting that way yet, or does anyone else find this to be the case.
please let me know... thanks
tjvtsportsman is offline
post #2 of 11 Old 10-02-2005, 01:46 PM
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
On the race track I always shift up clutchless but on the street I still use it sometimes. Clutchless upshifts work better when 2 things are true... You have a GP pattern shifter and you're in the upper RPM's when shifting. Its actually less smooth and slower to use the clutch in a racing situation.
Green Knight is offline
post #3 of 11 Old 10-02-2005, 02:05 PM
tlfreek's Avatar
well I agree with part of that. I do not have a GP config but I am much smoother on the track when not using the clutch.
tlfreek is offline
post #4 of 11 Old 10-02-2005, 02:26 PM
I upshift at the track without the clutch.
DethsZX10 is offline
post #5 of 11 Old 10-02-2005, 03:12 PM
a
a's Avatar
Usually upshifts and downshifts without clutch.Maybe litlle clutch on downshifts. Depends on corner entry. When you learn its quicker and smother.
Akrapovic slip on, race screen, champ sliders, steel brake lines,DID 520 chain and sprockets, ohlins shock, race tech steering damper, AIM lap timer and everythin in carbon fiber except tank.
ride it like u stole it
a is offline
post #6 of 11 Old 10-02-2005, 03:52 PM Thread Starter
cool thank u, i guess i just have to practice
post #7 of 11 Old 10-02-2005, 04:50 PM
BackMarker's Avatar
To do this you need to preload the shifter .....then just let off the throttle and get back on as quick as possible.
Don't let all the way off......just enough to make the gear change.
You'll find it will shift quicker than you can do...on/off/on again with the gas. Just preload a split second before you what to shift.
And ......only do this if your under hard acceleration.
BackMarker is offline
post #8 of 11 Old 10-02-2005, 07:24 PM
tlfreek's Avatar
well said.
tlfreek is offline
post #9 of 11 Old 10-02-2005, 08:07 PM
circusnuts's Avatar
When upshifting, I use the clutch as little as possible. This bike is the easiest I've owned to shift clutchless.
But you wouldn't want tell the Kawai service department you do this
Dress for the slide & not the ride
circusnuts is offline
post #10 of 11 Old 10-02-2005, 08:12 PM Thread Starter
iv'e been out practicing without the clutch and i figured out what i was doing wrong, you guys are correct, when done right clutchless is like butter and the 10 screams more and more please
quickshifter question speedfreak Performance and Tech 11 09-19-2005 09:58 AM
Air Box Question DarkTari Performance and Tech 10 09-09-2005 07:22 AM
shifting question for you smrat people king-tony Performance and Tech 6 05-05-2005 08:15 PM
A Question for you Brains out there - calling all PC3 nerds.JK GREENDEL Performance and Tech 2 04-23-2005 07:13 PM
Question on Accuman DG8 steves87 Performance and Tech 6 10-11-2004 04:24 AM
