reset sag - Kawasaki ZX-10R.net
post #1 of 10 Old 10-23-2005, 08:02 AM Thread Starter
reset sag
reset the street sag settings on the 10 from 28mm to 33mm and no more tire spin just squat and go I weigh 160lbs what sag are most of you boys running for the street?
bigolekaw is offline
post #2 of 10 Old 10-23-2005, 08:19 AM
Iceman's Avatar
Red face
Sag is standard,only changed rebound and compression settings. Never had a problem with unwanted wheel spin.
What`s behind,doesn`t matter.
Iceman is offline
post #3 of 10 Old 10-23-2005, 09:58 AM
Big Daddy's Avatar
Images: 38
I have 28mm rider sag but its with a Penske
Big Daddy is offline
post #4 of 10 Old 10-23-2005, 07:38 PM
madkaw's Avatar
28r and 32f.
He who dies with the most toys wins!
NESBA #24993
madkaw is offline
post #5 of 10 Old 10-24-2005, 03:14 PM
I set front and rear (with wheels off the ground, for the extended end of the measurement) at 30 mm. That's a generally recommended measurement for brisk pace public road riding. I can't say squat about the final outcome till it is final. But say next summer? RoK ON Oh, PS with all gear on, I'm 185, a runt with heavy gear
louemc is offline
post #6 of 10 Old 10-24-2005, 03:31 PM
Big Daddy's Avatar
Images: 38
is that your final answer??
post #7 of 10 Old 10-24-2005, 04:45 PM
sneaky's Avatar
Can you set sag with the bike on stands. I need to do mine and can not get ahold of anyone to help me out with getting the bike upright.
sneaky is offline
post #8 of 10 Old 10-24-2005, 05:26 PM
Big Daddy's Avatar
Images: 38
Find at least 1 person and you can manage Ok, otherwise its a futile attempt.
post #9 of 10 Old 10-24-2005, 07:10 PM
Ah, rear stand isn't going to cut it ( we are talking race stands here aren't we?) that type just raises the rear wheel off the ground, with the support on the swing arm, and as far as the suspension is concerned, the weight is still on the un-sprung part of the bike. I did all my measurements by myself, but, by taking off the lower plastic, and securing the bike with tie down straps (which can be a little loose, this is just an anti-tip over thing) and jacking and blocking under the engine to support the bike, for the off ground extention of suspension, and, a plastic tie strap (that can slide) on the front fork lower leg, and a board fastend across the passenger part of the seat and measurements between the board and the rear axle nut. It's a minor bitch but can be done. The worst part is backing off the rear spring retainer nuts, no where in history has a sport bike come pre loaded for two couch potatoes or one whale.
louemc is offline
post #10 of 10 Old 10-24-2005, 10:02 PM
Ground Zero's Avatar
Images: 7
28R (Ohlins), 38F (Ohlins) @ 155-160. Zip tie on the fork tube works great for the front but you will need a second person for measuring the rear.
Ground Zero is offline
For the Suspension GooRooRooRoo's... morrisjl2 The ZX-10R 18 05-24-2007 05:26 PM
Settin Suspension Sag hillcountry10r Performance and Tech 20 02-07-2007 04:31 AM
Need more help with my Gilles reset! AK10R Performance and Tech 0 08-18-2005 12:11 AM
Finally set up the sag... Ground Zero The ZX-10R 6 02-28-2005 08:05 AM
Settin Suspension Sag hillcountry10r How To... 2 02-05-2005 02:29 PM
