relocation of rear brake caliper on 2004 zx10r - Kawasaki ZX-10R.net
post #1 of 8 Old 06-24-2010, 06:52 PM Thread Starter
missedapex's Avatar
Hello,
Using stock wheels, has anyone found/made or come up with a solution to put the rear caliper on the bottom of the swingarm? Zx12r maybe, zx14r not, Attack whatever! Spacing on brake caliper isn't important: stock or Brembo. If anyone can fabricate (will pay through paypal) or point me in the right direction it will be greatly appreciated.
Thanks
missedapex is offline
post #2 of 8 Old 06-25-2010, 04:31 AM
or10r's Avatar
or10r is offline
post #3 of 8 Old 06-25-2010, 05:35 AM
Strik33r's Avatar
it is not possible to install a brembo rear caliper with oem wheels. so to do it you must find an underslung bracket for the oem caliper, and that will be VERY hard.
________
WENDIE 99
Strik33r is offline
post #4 of 8 Old 06-25-2010, 01:05 PM Thread Starter
missedapex's Avatar
I appreciate your response and the info you've provided. There is a company in Japan that allows you to use a Bremo (less 5% of the pad area so the caliper is mounted lower for clearence) but it's expensive. I was hoping someone had a similar experience as me and I could find someone who can fabricate or modify. Again, thanks....SBK and Motogp and......Formula 1 this weekend!
post #5 of 8 Old 06-25-2010, 03:24 PM
dirt ninja's Avatar
Images: 9
Well our buddy garth has done this mod and id like to know as well. Hopefully he will chime in.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #6 of 8 Old 06-25-2010, 04:18 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
that's what i was thinking when i first saw this thread too BUT i'm pretty sure he had aftermarket rims and was using the brembo rear caliper as well......
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #7 of 8 Old 06-25-2010, 10:07 PM
Of course you are faster
Rifleman's Avatar
hate to say, but on the Suzuki TLR... it's underslung OEM *S*
Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
And another amazing install write up click this
Originally Posted by Rifleman View Post
lol, once you go 1/5th... you NEVER go back
Rifleman is offline
post #8 of 8 Old 06-25-2010, 10:20 PM
PaSt's Avatar
The one that Garth has requires you to have Marchi's on, I have seen PVM advertise one that you can get, but I dont know how compatible it is with the 04-05 swing arm and stock wheels.
The ZX14, I believe has a different inner rim Diameter, so that wont work.
CARROZZERIA does not make em for the Kawis.
I've had mines (ladybird) for a while but its not a perfect fit, im ok with it cause I don't use the rear brakes enough.
I know there is a Brembo bracket for the 08-10 models but that requires you to change the rear swing arm.
I have talked to Champ about making these, which reminds me, I keep forgetting to contact him for the rest of my parts. So champ, if you see this, oops.
PaSt is offline
zx10r rear underslung brake caliper kit garth285 Parts, Gear and Accessories 2 04-19-2010 07:19 AM
Rear brake caliper Ducati Killer Performance and Tech 9 03-01-2010 08:13 PM
08-09 Rear Brake Caliper and MC RAINMAN Parts, Gear and Accessories 2 10-18-2009 11:31 AM
05 rear brake caliper 05Green_ZX10R Performance and Tech 6 03-18-2009 01:34 PM
*SOLD*FS: 2004-2005 ZX10R Rear Hel Brake Line MyZuC Parts, Gear and Accessories 1 05-23-2008 12:28 PM
