? for our auto mechanics - Kawasaki ZX-10R.net
post #1 of 21 Old 09-30-2009, 01:06 PM Thread Starter
Mythical Mod of Yore
wicked's Avatar
Send a message via AIM to wicked Send a message via MSN to wicked Send a message via Yahoo to wicked
I have a 99 Honda Passport. On the highway on the way home from work yesterday I started hearing a squealing noise from under he hood that sounded like belts needed adjusting. This morning I went to take the kids to school and when I started my car there was a loud squealing, the smell of burned rubber and smoke coming out from under the hood. Popped the hood and the serpentine belt wasn't moving. Obviously something has seized. So I want to know what the simplest method for telling WHATS seized. Is it as simple as removing the serpentine and turning the pulleys by hand? I hate to take it to the shop if I can figure it out myself...ESP since towing, diagnosing and fixing would probably cost more than the damned things worth
thanks in advance!
- Doc
wicked is offline
post #2 of 21 Old 09-30-2009, 01:08 PM
lyodbraun's Avatar
might be the water pump that went out is there any anifreeze leaking or smell any ??
lyodbraun is offline
post #3 of 21 Old 09-30-2009, 01:13 PM
Quick10's Avatar
Might also be the A/C compressor, alternator or power steering pump...I would see what you could turn by hand and whatever you can't is your most likely candidate.
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #4 of 21 Old 09-30-2009, 01:17 PM
dirt ninja's Avatar
Images: 9
Take the belt off and spin all the pulleys. Also take a look at the belt tensioner. Ac compressors are known to lock up. See of the clutch is locked up on the ac compressor as well. You'll probably just need a 1/2'' ratchet to release the tension on the belt tensioner. You will be able to see what is seized by turning them by hand.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #5 of 21 Old 09-30-2009, 01:21 PM
ducatibrandon's Avatar
Images: 18
Send a message via Yahoo to ducatibrandon
All the above but you will find it. My guess is the Tensioner / idler pully
ducatibrandon is offline
post #6 of 21 Old 09-30-2009, 01:22 PM Thread Starter
wicked's Avatar
No...and I watched the temp guage the whole way home yesterday and it never fluctuated...
- Doc
wicked is offline
post #7 of 21 Old 09-30-2009, 01:25 PM Thread Starter
wicked's Avatar
Thanks guys. I was hoping diagnosis would be that simple.I swapped out the tensioner about a year ago but I DID get it from the junk yard...
- Doc
wicked is offline
post #8 of 21 Old 09-30-2009, 01:31 PM
cuhuba's Avatar
These guys are correct. My money is on the tensioner. Water pump would weep before it seizes and A/C clutch should stay disengaged when dead.
Ride like you pay a mortgage...
cuhuba is offline
post #9 of 21 Old 09-30-2009, 01:41 PM
diesel10R's Avatar
i would check your tensioner......i will strees never get something like that from the junk yard....most(not all)cars that I run into have timing belt driven water pumps...if tensioner is good my guess would be a/c compressor..not too many things will lock and stop the belt from moving??I have seen alternators lock-up but usually it is from sitting for an extended period(brushes,ect. rust together)and it was like the motor was siezed until i took belts off!!very 1st step remove belts! and hope i helped!!
Dan
ride or die!::weed :
diesel10R is offline
post #10 of 21 Old 09-30-2009, 01:41 PM
mykids's Avatar
All of the above except it can't be your water pump because it is ran by the timingbelt not the serp. belt
mykids is offline
A&P Mechanics.... Nick.INF The Out House 9 05-15-2009 06:22 PM
Any mechanics in the house? srleadjb Performance and Tech 16 10-22-2008 05:50 PM
Any mechanics on here? BrockLanders The Out House 8 02-12-2008 10:06 AM
Car Mechanics..? yellow10r The Out House 11 12-12-2007 10:03 PM
? TO AUTO MECHANIcs. zixxer The Out House 9 12-07-2005 05:12 PM
