oil leak after layed bike on laft side HELP - Kawasaki ZX-10R.net
post #1 of 4 Old 08-14-2010, 12:32 PM Thread Starter
chucks ss's Avatar
Went down on a corner , sand in road. Only damage to 06zx10r was cracked stator cover .got a new one on order , put jb weld on for now but still getting oil leak from somewhere , I'm mechanically inclined , bit I'm lost. , not coming from any over flow tubes , need ideas or past experieances , could it be the gasket , or hidden crack around bolt hole , I know u can't tell withou looking just wondering if anyone else had the same prob . Seems to be oil dripping under stator cover area , also my throttle stuck on me a couple times , bike went down on opposite side any suggestions. , thanks for the help.
chucks ss is offline
post #2 of 4 Old 08-14-2010, 01:25 PM
tasos's Avatar
maybe lower crankcase or belly pan? Some pics would help...
tasos is offline
post #3 of 4 Old 08-14-2010, 02:17 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
It may not be leaking when the bike is setting still BUT once it's running there's a chance it's pushing oil out of the stator cover but as tasos mentioned, pics might help track down the culpret.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #4 of 4 Old 08-14-2010, 03:33 PM
Teeks's Avatar
Jb weld is also not the be all end all to stop leaks. Especially if there is any residue at all from where you applied it.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
well i layed her down today :( HOOCH The ZX-10R 29 09-22-2009 06:09 PM
04 Layed down right side, Clutch not fully disengaging? fourdoorracer The ZX-10R 5 06-26-2008 10:56 PM
Layed bike down.. blackisfaster The ZX-10R 17 06-04-2007 01:05 AM
Just layed my 9R over...FUUG. R1GSXRKILLER The ZX-10R 38 03-01-2005 08:24 AM
Layed my new ZX10 down GARSZX10R The ZX-10R 15 05-30-2004 07:34 PM
