Lost a wheel bearing on the truck today - Kawasaki ZX-10R.net
post #1 of 7 Old 11-14-2010, 04:59 PM Thread Starter
Of course you are faster
Rifleman's Avatar
Just got done fixing the passenger side wheel bearing on the Dodge. Sounded kinda like the brake pads were rubbing, but it got worse when you turned to the left and the brakes felt fine, even when under hard pressure.
so I pull it apart and sure enough, it's the $139 wheel bearing and not the $28 brake pads... well I did both, the pads needed changing as well
so, 2 hours and some coin later, El Diablo is back up and running, not what I had planned for a sunday afternoon but glad it happend now and not when I was on the road heading out for deer hunting this week.
Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
And another amazing install write up click this
Originally Posted by Rifleman View Post
lol, once you go 1/5th... you NEVER go back
Rifleman is offline
post #2 of 7 Old 11-14-2010, 05:04 PM Thread Starter
Rifleman's Avatar
poop, someone move this please, it's supposed to be in the out house, not here
Rifleman is offline
post #3 of 7 Old 11-14-2010, 06:41 PM
Supercharged Mod
Moved.
Most newer vehicles have sealed wheel bearing hub assemblies that cost a lot more than $139, so count your blessings.
GoFaster is offline
post #4 of 7 Old 11-14-2010, 06:55 PM
bluedevil's Avatar
Originally Posted by GoFaster View Post
Moved.
Not only that you need some BIG tools sometimes and a job like that can cost you up to $500 with parts and labor maybe more. My step Daughter had her's done at a shop and it was $350....I would have done it for her but I didn't have the Big Impact sockets at the time that matched......won't be a problem next time I bought a great Impact set with multiple socket sizes in a sturdy Plastic case from Harbor Freight I believe for around $35 on discount. I used it to replace some half shafts already on a ford explorer and saved some $$$ right off the bat there.
bluedevil is offline
post #5 of 7 Old 11-14-2010, 09:11 PM Thread Starter
Rifleman's Avatar
I have a 3/4 driver Chicago Pnumatic impact wrench, and a set of sockets that go up to 2 inches That's gitt'n her done.
I have a million dollar man who I can consult with, he knows everything. I count myself lucky that I can spend the money on parts and get it done in one afternoon.
feels good to identify the problem, pull it apart, fetch the new parts and get'er back together.
Rifleman is offline
post #6 of 7 Old 11-14-2010, 10:09 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
How many people can't even check or adjust tire PSI, nowadays. I always picture my dad in the garage cussing after busting his knuckles and teaching me how to use the different tools. Props to you for fixing it on your own.
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #7 of 7 Old 11-15-2010, 04:50 AM
or10r's Avatar
That sucks man. I just did the rears in my car last month and it wasnt too bad. I had to get someone to press them out. My 50 ton press wouldnt budge them. Other then that it was a pretty easy job. Sounds like yours was a little more difficult. Cool that you got her done though!
or10r is offline
'04 wheel bearing specs? caboose Performance and Tech 5 11-19-2008 08:41 PM
Wheel Bearing Removal Tip JOSHUAZX10 Performance and Tech 7 03-09-2008 03:18 PM
wheel bearing JeredH Performance and Tech 12 11-10-2007 10:54 AM
04 front wheel bearing and seals hesaves0211 Vendors deals 6 06-22-2007 01:15 PM
wheel bearing removal 10roller The ZX-10R 9 05-09-2006 04:00 AM
