How did they make these?? - Kawasaki ZX-10R.net
post #1 of 29 Old 12-08-2011, 05:15 PM Thread Starter
RDLYN13000's Avatar
Images: 38
How do you all think they made/installed these LED's in the wheels? Ive looked around and found cheap little kits that look nothing like this and mount in the wheels wells. But these look like they are coming from the rotors?? And they are extremely bright!! Im not looking at buying/installing these on anything I have and dont care if you dont like them thats not the point of this thread. Im curious how if you know how they are actually doing this or what they are using??
RDLYN13000 is offline
post #2 of 29 Old 12-08-2011, 05:16 PM Thread Starter
RDLYN13000's Avatar
Images: 38
post #3 of 29 Old 12-08-2011, 05:28 PM
SkyDork's Avatar
Well, they are definitely mounted to the rims. They spin with the wheels. There's probably some sort of slip-ring arrangement to get power to them. Similar to how the armature in a motor works. That's what I would think.
#WordCrimes
SkyDork is offline
post #4 of 29 Old 12-08-2011, 05:40 PM Thread Starter
RDLYN13000's Avatar
Images: 38
Everything I find says coming 2012, cant find em anywhere. I'll keep looking, my buddies got a nice caddy with wheels and wants em
post #5 of 29 Old 12-08-2011, 05:46 PM
SkyDork's Avatar
Can't really help you out on sourcing them. Never seen them before. I've seen similar, but it would fall into the "cheap" category.
#WordCrimes
SkyDork is offline
post #6 of 29 Old 12-08-2011, 05:48 PM Thread Starter
RDLYN13000's Avatar
Images: 38
Thats what im finding too, I figured if I could figure out how they are mounting/wiring them and what LED's they are using I could just make some for him...
post #7 of 29 Old 12-08-2011, 05:54 PM
SkyDork's Avatar
You probably could. It wouldn't seem that hard to do once you figure out the slip ring arrangement for power. Run the wires down the axle and then to the slip ring to transfer power through the rotational axis. It's done all the time. What comes to mind is an arrangement like on airplane propellers where there's electric heating elements on the prop blades. The prop turns and there's a couple of wires that run around a stationary loop. That's how they get power out there while the prop rotates.
Then you just run the LEDs in the rims. Once you get the power transfer figured out, the rest is pretty simple. At least it would seem so. In practice, getting it look good and light up with the light directed properly might take some time.
#WordCrimes
SkyDork is offline
post #8 of 29 Old 12-08-2011, 05:58 PM Thread Starter
RDLYN13000's Avatar
Images: 38
Makes sense, I did just locate these on ebay. I wish he had some better pics!
http://www.ebay.com/itm/Wheel-lighti...item3a6b0a9433
post #9 of 29 Old 12-08-2011, 06:04 PM
SkyDork's Avatar
Those don't look bad. I wonder if they're battery operated with the RF control box. That's obviously the easiest method, but would require batteries. Eh, for $200 bucks it might be worth getting that kit and using it as-is or mod it to suit your needs.
#WordCrimes
SkyDork is offline
post #10 of 29 Old 12-08-2011, 06:08 PM Thread Starter
RDLYN13000's Avatar
Images: 38
Yeah $200 isnt terrible, I sent my buddy the link we will see what he does
How to make a TRE? ZX10C2 Performance and Tech 54 02-16-2016 10:12 AM
this will make you cry Static IP The Funny Pages 8 01-25-2008 07:55 PM
Did he make it? Kawa_Brian Pictures and Videos 32 01-04-2007 07:54 PM
Anyone know if they make these..... GreenMachine666 Performance and Tech 5 01-26-2006 07:50 AM
Can anybody else make it? 1killer1liter Race and Stunt 2 10-12-2005 12:22 PM
