Help Me Please Asap - Kawasaki ZX-10R.net
post #1 of 15 Old 02-22-2007, 11:07 PM Thread Starter
Help Me Please Asap
ok ive worked on cars and bikes and pretty much everythig tht has a motor all my life and i have never seen anything like this. im changing brakes and rotors on a 98 mystique and i cant get the rotor off to save my life . ive beat the hell out of it with a hammer, heated it, tried pb blaster nothing. anybody with any ideas
full micron exhaust,pcIII dyno tuned,BMC race filter, kawi .50 thin head gasket ,hyperpro rsc dampner,goodridge ss line,16/41 setup,D.I.D gold chain, hotbodies smoked windscreen, smoked flush mounts, rifleman 1/5 throttle insert,pazzo shortys,fender eliminator, removed secondaries. ZX-10R.NET WRISTBAND
"IF IT AINT MODDED IT AINT YOURS!!"
Zx10R
Evolution IX MR
Dodge Ram
zx10r85 is offline
post #2 of 15 Old 02-22-2007, 11:13 PM
MIA mod
gpz1100's Avatar
Sounds like you've tried all the usual stuff. Looked at a service manual? Maybe there's something like a retaining screw. All else fails, C4 will take it right off there for sure.
gpz1100 is offline
post #3 of 15 Old 02-23-2007, 12:03 AM
Post Whore
Sgtusmc96's Avatar
LOL A lot of help you were!!!
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #4 of 15 Old 02-23-2007, 12:05 AM
MIA mod
gpz1100's Avatar
Well, think about it. Beat it, heat it, lub it, what else is there to do. Oh, oh, what a minute....Try pulling the tire off first. Doh!
gpz1100 is offline
post #5 of 15 Old 02-23-2007, 12:06 AM
alteredZX-10's Avatar
c4 sounds good to me
www.alteredchrome.com
Its done!! Check it out!!
alteredZX-10 is offline
post #6 of 15 Old 02-23-2007, 03:08 AM
bobsp1's Avatar
gpz1100 could well be right, a lot of vehicles have a retaining screw.
Stand back from the job for a while and have a good look over it, use a torch and mirror to look behind the rotor and hub as well, you never know what is lurking there....manufacturers love pissing off home mechanics, it's how they get their perverted thrills.
bobsp1 is offline
post #7 of 15 Old 02-23-2007, 06:24 AM
Also if these are the front rotors, you need to check to see if the axle/half shaft retaining nut also holds the rotor in place over the wheel bearing/hub assembly. I've seen a couple of cars that were set up that way. If this is the case, you'll need a big socket which is typically something like a 36 mm and a big breaker bar. If you're fortunate to have access to a 1/2" impact gun, then it should be pretty easy to knock off.
ZX10 Guy is offline
post #8 of 15 Old 02-23-2007, 07:34 AM Thread Starter
i have looked everywhere for retaining screws, and i already took off the axle nut, think the same thing
Zx10R
Evolution IX MR
Dodge Ram
zx10r85 is offline
post #9 of 15 Old 02-23-2007, 07:53 AM
MIA mod
gpz1100's Avatar
Do you have access to a service manual? Maybe online forum for that make of car? There has to be some reason it's not coming off (yeah, no kidding, right) using the usual methods.
gpz1100 is offline
post #10 of 15 Old 02-23-2007, 08:05 AM
rabbit's Avatar
I have the ford service manual for 98 at my house, but you'll have to wait until tonite for me to access it. Hondas all use a single phillips head retaining screw, I'd bet there's something there that you're just not seeing. BTW, I hope that was a rubber mallet you were hitting it with......
rabbit is offline
I Really Need A 04-05 Radiator Asap!!!! garth285 Wanted: Buy or Trade 3 02-25-2007 07:45 PM
Need help ASAP! modpup The ZX-10R 6 02-18-2007 11:27 AM
need help with my s-10 asap Nick.INF The Out House 5 05-19-2006 08:57 PM
NEED HELP ASAP gixxerich The ZX-10R 8 05-25-2004 11:04 PM
