h.i.d problems - Kawasaki ZX-10R.net
post #1 of 3 Old 11-06-2012, 10:04 AM Thread Starter
nfranke's Avatar
h.i.d problems
This isn't on the ten. But i gave a hid set as a birthday present and the set had been giving the personal problems. The lights would go off when coming to a stop and then come back on. The high beams didn't work either.
I went to look at them last night as I'm the one who installed them. I was expecting to find the kit harness plug loose from the head lamp harness as when i installed the lights the head lamp plug would not lock into the harness plug as it is supposed to. But when examining the harness I found the inline fuse from the positive side of the battery melted but still functional .
I was at a loss. I had never seen or heard of a fuse doing that. I did replace it for a time to try and track down the loose connection. I couldn't nail down a cause.
So now my question is there anyone with experience trouble shooting h.i.ds. do you think its the control box on the harness or the plug or both.
Originally Posted by Static IP View Post
Biker#1 "oh no you didn't, you best gimme my latte or imma bust a cap"
nfranke is offline
post #2 of 3 Old 11-06-2012, 10:11 AM
jdub669's Avatar
The ones i had in my a8 would Shut off under braking and hitting bumps they would flicker. Turned out to be inside the actual ballast. The ignitor would ground out against the case. Bought a reputable brand and never had problems again. Don't buy Shitty hids. Your gonna be upset when they melt your harness.that's my experience atleast. Good luck
Sent from my SAMSUNG-SGH-I717 using Motorcycle.com Free App
"mechanical engineers build weapons, civil engineers build targets"
jdub669 is offline
post #3 of 3 Old 11-06-2012, 12:31 PM Thread Starter
nfranke's Avatar
Didn't really think of the ballast but that's a possibility
Sent from my DROID RAZR using Motorcycle.com App
nfranke is offline
Gen 4: Problems... Alex888 The ZX-10R 5 03-21-2012 09:00 PM
problems.help William Hell The ZX-10R 11 10-02-2011 05:56 PM
Back wheel problems ??? g-pack problems ???? Arby The ZX-10R 2 08-04-2009 08:01 PM
PC III problems 06zx14r ZX-14 Discussion 5 04-24-2008 05:19 AM
gas problems Zxrider Pictures and Videos 0 01-27-2005 03:44 PM
