Forearm fatigue - Kawasaki ZX-10R.net
post #1 of 19 Old 07-18-2006, 09:15 AM Thread Starter
Forearm fatigue
Hello all,
I've never seen this issue discussed here but is there anything I can do to reduce forearm fatigue while riding?I'm no wimp , I work out daily and I'm in shape but it is an issue with me. Are there any specific excercises to help?
Thanks in advance.
Darren
Darren797 is offline
post #2 of 19 Old 07-18-2006, 09:22 AM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
ride slower.
And put all the weight on your legs. You should NEVER be gripping the bars tightly.
And if you are, its prolly cause youre riding to fast for your comfort level, and yorue stressing out.
Just concentrate on relaxing and keepin the weight on your feet.
James 3:7,8
hillcountry10r is offline
post #3 of 19 Old 07-18-2006, 09:26 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Originally Posted by hillcountry10r
ride slower.
+1 You hold on with your legs not your arms
zx10ragentblack is offline
post #4 of 19 Old 07-18-2006, 09:53 AM
Macke's Avatar
Images: 40
Send a message via MSN to Macke
The best thing to do, is to try to think how you are using your arms when riding. Really focus on relaxing, and not gripping the handlebars to tight. That's usually the biggest reason for this. I have noticed that the more excited or nervous I am, and the tighter the race is, the more tired I get in my forearms. This is because I tense up, and try to force the bike into every corner, and really wrestle the bike around.
Also, check that your leathers aren't too tight around your forearms. This will obstruct the bloodflow, and make the forearms really cramp up.
I've been having some problems with this when racing for some time now, and apart from practising on your bike every day, there are a couple of good exercises for the forearms that I use.
1) I use a kind of gyro-ball that I bought at a gadget store, works great. It's a bit tricky at the beginning, but when you get it right, its really good exersise.
2) Take a short pole (cut off a broomstick or something). Attach a string (about 3-4 ft.) to the middle of the stick, and then a weight at the end of the string. (Try different weights, until you find the right one).
Then grip the short pole with both hands, arms straight forward, and wind up the weight all the way up, and then back down. Do this both with the knuckles facing up, and facing down (works different parts of your forearm).
3) Use the classic "squeese-spring-thingy". (Have no idea what they are called) You know, the one that looks like a set of pliars or something, and a spring inbetween.
Edit, found a pic.
Try to work with lighter weights and a lot of reps, rather than heavy weights and fewer reps. This will increase your muscle stamina, and not build volume. (Don't want the leathers to get to tight around your forearms)
If you can't race fast, atleast you can look fast...
Macke is offline
post #5 of 19 Old 07-18-2006, 09:56 AM
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
I agree with all of the above. I had the same problems until I talk with a experienced rider. The key is to relax and shift your weight to legs and feet.
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
post #6 of 19 Old 07-18-2006, 10:00 AM
Rembrant's Avatar
I was told a few years ago to always keep your arms bent at the elbows a bit....this will force you to use your core or trunk muscles to hold yourself upright, rather than keeping your upper body weight on your arms.
Squeeze with your legs, and keep thinking of using your body while keeping your hands loose on the grips.
JMTCW
Rembrant is offline
post #7 of 19 Old 07-18-2006, 12:07 PM
FAF
Rent this space
25 push ups on your knuckles every day
FAF is offline
post #8 of 19 Old 07-18-2006, 03:36 PM
ram360's Avatar
Send a message via AIM to ram360
I agree with everything above since you brought up exercises. do some forearm curls and reverse forearm curls. You can use dumbbels or even a straight olympic bar. Basically duplicates the exact motion you use when using the throttle of a bike.
ram360 is offline
post #9 of 19 Old 07-18-2006, 03:58 PM
Zega's Avatar
My forearms have never been an issue, yet I do feel or at least did feel it in my wrists initially but my body seems to have adapted. Especially town riding where your weight is on the bars from start stop etc. on the open road with more speed I noticed there is less weight concentrated onto the bars which aleviated the pain in my wrists, but then I also have past injuries in these areas. Also as I got more used to the bike I was able to distribute my weight better so as to not pump it all into the bars.
Zega is offline
post #10 of 19 Old 07-18-2006, 05:01 PM
morrisjl2's Avatar
Good post....Always good to be reminded how to ride fast and cumfy.
morrisjl2 is offline
forearm pain while braking Mustard The Out House 17 04-20-2006 08:43 PM
Throttle Fatigue Poky The ZX-10R 28 01-28-2005 09:57 AM
