Electric Shifter or Air Shifter??? - Kawasaki ZX-10R.net
post #1 of 9 Old 10-18-2005, 08:58 AM Thread Starter
Stud_wit_style's Avatar
Send a message via MSN to Stud_wit_style Send a message via Yahoo to Stud_wit_style
Opinions??? By the way...I have Sato Rearsets(if that makes a difference).
2007 Toyota Tundra SR5, 2WD, DCAB, 5.7L, JBL Audio System, Fast as F*%k
Stud_wit_style is offline
post #2 of 9 Old 10-18-2005, 09:33 AM
Ground Zero's Avatar
Images: 7
I really like my Dyno Jet quick shifter. Setup/install is easy and it works great. I have the Satos as well.
Ground Zero is offline
post #3 of 9 Old 10-18-2005, 10:06 AM
MIA Post Whore
miykl's Avatar
I like the quick shifter also, but if you are looking for a true shifter my prefferenc is the electric type. I've had both. The electric is more of a hassle to set up, but once it's done there are no more worries. plus it's much ligher that an air shifter. Air shifters can have leaks, need to be refilled....... One plus of the air shifter, if you run nitrous, you can run both off a single bottle. But, when you run low, bad shifts can occur. I vote electric.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #4 of 9 Old 10-18-2005, 10:17 AM
Ruthless Racing's Avatar
Images: 9
I'm thinking of getting the Quickshifter, it works right off your PC3USB.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #5 of 9 Old 10-18-2005, 10:33 AM
That is all that I see if air shifters. I'm suprised that more people don't run electric shifters. They don't take up as much room as an air shifter and seems to be lighter also. If I was you, I would get the electric shifter.
"That's like going to Heaven and finding Jesus smoking Crack!!!!!" Riley from "The Boondocks"
Check out www.L17racing.com
Thumpdaddy is offline
post #6 of 9 Old 10-18-2005, 10:35 AM
lexusrx's Avatar
electric.
Retail is for squids. Shop like a pro at Superbike Supply.
[email protected]
https://www.facebook.com/superbikesupply
www.forum.superbikesupply.com
1-828-287-2101
lexusrx is offline
post #7 of 9 Old 10-18-2005, 10:43 AM
busaforhire's Avatar
electric for road racing and air for drag racing... the electric can keep shifting and shifting where the air shifter has to have a compressor or a way to fill the air tank. as for leaks.. thats only going to happn in a poorly set-up shifter. I had 120 lbs. of air in my air shifter all winter one year. it would drop a little with temp but then come right back up when It was warmer.
I have the quickshifter with the satos as well and I have to tell you this is the absolute best way to go overall IMO. It took me a while to get used to it but now it's just as fast as with an airshifter for sure and it requires you to cut not one single wire.
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
post #8 of 9 Old 10-18-2005, 12:48 PM Thread Starter
i forgot about the dyno quick shifter...ill look into that too. thanks...
post #9 of 9 Old 10-19-2005, 06:41 AM Thread Starter
anyone know any good prices out there for the dynojet quick shifter? so far ive seen a little under $300...
Ram Air Leaks swjohnsey Performance and Tech 15 01-13-2008 08:09 PM
Ram air rubbers miykl Performance and Tech 9 02-20-2006 11:19 PM
Air box removal? fun2fly Performance and Tech 37 12-19-2005 11:35 AM
Air Filter questions. green04zx10r Performance and Tech 5 09-07-2005 11:17 AM
Interesting letter written to K&N about air filters gladding24 Performance and Tech 7 10-23-2004 12:34 AM
