Car repair question (rattle noise) - Kawasaki ZX-10R.net
post #1 of 14 Old 09-29-2012, 12:28 PM Thread Starter
RightCoastRipper's Avatar
My girlfriend has a 2002 Mustang (v6 model). When putting the car into and out of park it makes a harsh grinding/rattle noise. Its almost a clunk sound, but I would like to fix it for her. The car also produces a bit of a shake too.
Obviously it could be a lot of things but is there anything that this car is notorious for?
Exhaust leak?
@SUPRAMAN42
RightCoastRipper is offline
post #2 of 14 Old 09-29-2012, 12:34 PM Thread Starter
And yes I have searched the web a bit. I WILL NEVER OWN A FORD lol. I do not know many people who have luck with them, and googling this problem there is a million things on noises and viboration coming from the vehicle, and some of the responses people are like:oh yeah I had this happen on a few of my explorers and other fords lol
@SUPRAMAN42
post #3 of 14 Old 09-29-2012, 12:41 PM
nczx-10r's Avatar
not sure but being it has a shake possible bad torque converter????......
ITS BETTER TO BE HATED FOR WHAT YOU ARE...
THAN LOVED FOR WHAT YOUR NOT..................
nczx-10r is offline
post #4 of 14 Old 09-29-2012, 12:53 PM
rayanb's Avatar
Maybe motor mounts, or transmission mount.
Werkes exhaust, Tech spec center and side grip pads, ZG Corsa windscreen, Alien Motion 8 cell battery, Hotbodies smoke undertail, Green decals, Hellsrazor servo fix. More to come.....
rayanb is offline
post #5 of 14 Old 10-02-2012, 10:37 AM
nekolak's Avatar
I would check engine mounts. I had a similar problem with my car. You could actually see the engine move when shifting. Does reverse give you a similar sound?
nekolak is offline
post #6 of 14 Old 10-02-2012, 10:49 AM
tylerzx10r's Avatar
i would check the u-joint first you can change the front and rear for about 20$ and less than an hour of work. it will cause a clunk when putting it in and out of gear and will cause a vibration
tylerzx10r is offline
post #7 of 14 Old 10-02-2012, 03:07 PM Thread Starter
I will see if I can play with it when she is off to see what gear it does it in and get a better description of the problem.
@SUPRAMAN42
post #8 of 14 Old 10-03-2012, 11:06 PM
rkd
Best to jack it up and look underneath. Check the u joints, trans and engine mounts, shift linkage, etc.
Pull the torque converter cover and check for loose converter bolts, flexplate damage.
Exhaust or other random loose parts.
Past that, it may be internal to the trans. Is it a 4r70w or an A4ld/4R444?
rkd is offline
post #9 of 14 Old 10-08-2012, 09:49 AM
The Pace
scout's Avatar
hey, if she doesn't ask, don't do anything. If me, and she does complain, I'd pretend not to hear her!
scout is offline
post #10 of 14 Old 10-08-2012, 10:28 AM
if its a clunk sound then i would start with the u-joint. my jeep used to make a clunk sound anytime took it out or put into gear changed u-joint and problem fixed
Lima Bravo is offline
Gen 4: 2012 zx10 making a rattle or valve noise gunreaper The ZX-10R 30 01-02-2017 01:00 PM
Rattle in my gen 1 quakeman3 The ZX-10R 5 04-02-2012 05:27 PM
Rattle be gone....... nczx-10r General Motorcycle Discussions 4 07-02-2009 05:57 PM
cracked tailpiece tabs repair question on 04 zx-10 kevenater The ZX-10R 9 03-05-2009 11:09 AM
Rattle Noise 808ninja The ZX-10R 7 04-19-2004 10:33 PM
