Bike problems - Kawasaki ZX-10R.net
post #1 of 7 Old 09-28-2006, 08:01 PM Thread Starter
Rock_Star's Avatar
Exclamation HELP - Bike problems!!
On my wifes 99 R6, i know its a yamaha, after a short ride she gets some electrical short or something (Im assuming, the generator?)
The symptoms are:
1. Gauages will stop working or flash during low RPM's and the bike will stall. During this time, all lights stop working (tail light, head light). If the bile stalls the battery seems to be very low and bike will not crank. But I can push start it.
2. High Rev's will keep the bike from dying.
3. Using the blinkers will cause sypmtom #1 and flash faster than normal.
** I replaced the battery 2 months ago. The bike always cranks right up and has no problems. However, the battery seems to have a low charge on it.
Does anyone know WTF this is?
Thanks,
Rock_Star is offline
post #2 of 7 Old 09-29-2006, 09:52 AM Thread Starter
Rock_Star's Avatar
anyone??
post #3 of 7 Old 09-29-2006, 09:54 AM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
sounds like a generator would be the problem...
try putting a volt meter on the output to see what V you get. I would ASSUME it should be a bit over 13v.
James 3:7,8
hillcountry10r is offline
post #4 of 7 Old 09-29-2006, 10:35 AM
oz914's Avatar
I bet the generator is the problem. I'm not sure if they still do this but I ran into the same problem on an older bike and the belt that goes from the generator to I would guess the crank was broken. The part was really cheat and pretty easy to put in....
07' Blue ZX-10R Lowered, Fender Eliminator,PC3, TRE, Ivan's custom tune, Frame Sliders, Helibars and Racefit Growler...............
05' ZX-10R SOLD......
oz914 is offline
post #5 of 7 Old 09-29-2006, 10:42 AM
Still here
ZX10Miami's Avatar
Believe it or not I have had the same symptoms on an fzr 600- turned out the battery cable had loosened.
Since you have probably checked that- also check for loose or dying fuse, loose connection from on/off bar switch. Those switches can also start to go bad losing the connection intermittently.
I'd check that stuff before going to the gen.
Depending on why you changed the batt 2 mos ago (was it the original old batt?) or did it just up and die? Maybe it is the gen, but check the easy stuff 1st.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #6 of 7 Old 09-29-2006, 10:52 AM
caboose's Avatar
Send a message via MSN to caboose
my gf's 02 R6 just went thru the same thing. hers turned out to be a regulator problem, problem being that it was fried. she's going to go get the stator checked out too to make sure its outputting properly but changing the regulator got it back running normally again. with hers, one of the wires going to the regulator was cooked too so i needed a new plug and soldered it on there. she's been running fine for a week now.
2010 10R Superbike
caboose is offline
post #7 of 7 Old 09-29-2006, 12:00 PM Thread Starter
Rock_Star's Avatar
ya, the more I thought about it... it may be the regulator rectifire(spelling) or the ground coming off the battery.
I will look at the ground connection tonight.
Ive got problems shenanigans The Out House 10 09-26-2006 09:22 PM
i need help with a few problems sturgill_13 Performance and Tech 13 09-20-2006 11:48 PM
06 ZX-10R problems Vegas06 The ZX-10R 4 03-22-2006 07:55 PM
Bike Problems DustinR The ZX-10R 9 09-14-2005 12:47 PM
Problems!! KidCapri50 Performance and Tech 19 08-06-2005 11:07 AM
