Any one good with automotive services? need help :) - Kawasaki ZX-10R.net
post #1 of 6 Old 08-13-2010, 12:20 PM Thread Starter
5-F Dawg's Avatar
'96 F150 5.0 XLT starter does not disengage
I go to start the pickup and it starts fine but when i release the key the starter keeps trying to start the truck...i turn the ignition to the "off" position, key out and everything and the starter keeps on spinning...likes it still trying to start....in the last year AutoZone has replaced 4 starters for me, an ignition, and a solenoid...
I hear AutoZone stuff stinks, and that I should spend the money for a MotorCraft starter, etc
any ideas as to why the starter still stays on even when the key is out of the ignition?
seems to me the the starter is still getting power, either from the solenoid/ignition? does this seem correct?
Rich
BOOM!!! SHAKE AND BAKE
5-F Dawg is offline
post #2 of 6 Old 08-13-2010, 12:27 PM
drock41's Avatar
Send a message via AIM to drock41
alright. gotta do it..... if you knock off that blue oval on the front of the truck, it will quick breaking on you!
but seriously i highly doubt it is your starter its self becuase when you turn that key off the power should stop going to the starter
"Faster, faster, until the thrill of speed overcomes the fear of death."
drock41 is offline
post #3 of 6 Old 08-13-2010, 12:29 PM
strkd50's Avatar
Sounds like the solenoid sticking, try one from a better parts house than Autozone. If you want to test it, next time it sticks put a test light on the ign. terminal on the solenoid and see if its hot. If its not I would say solenoid, if it is take a look at your ignition switch.
2012 ZX-14R
#228
strkd50 is offline
post #4 of 6 Old 08-13-2010, 12:34 PM
gomer's Avatar
Sledge hammer to autozone part, got to another parts place and praise them for not ripping you off.
But To what strkd50 said
05 Titanium
gomer is offline
post #5 of 6 Old 08-13-2010, 01:29 PM
Teeks's Avatar
Agree with all the above, ignition switch or solenoid. I wont say Autozone is horrible, but for the most part you get what you pay for, i think that says enough. Not that you always need to buy the most expensive parts, but on many electrical components, and hard parts like ball joints, tie rods, etc you dont want to skimp if you can afford not too.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #6 of 6 Old 08-13-2010, 06:04 PM
torqczar's Avatar
low voltage makes the solenoid stick.... check and clean all battery connections from battery to the starter, pos. and neg. cables , do you have temporary battery terminals the kind that bolt on and pinches the battery cable in the terminal? on fords the battery cables corrode inside the terminal, to diag. you need 12 volt meter put red probe on battery pos. the black probe on starter pos. terminal crank motor check volts while cranking. read meter the number is the voltage loss should be less than 00.10 volts. then do the same for negative side, neg. battery to motor ground less than 00.10 volts. that's to many starters to be bad, or just go get some new cables and be done with it...
torqczar is offline
If anyone needs automotive help. green10 The Out House 65 04-26-2010 06:15 AM
anyone know about automotive paint (custom) spikespiegel The Out House 6 11-20-2009 11:57 AM
To all the arm services SOUN1 Pictures and Videos 2 12-24-2008 03:37 AM
The best automotive GPS??? Ruthless Racing The Out House 4 08-27-2007 01:07 AM
Automotive or Motorcyle Mechanic? trbltriage The Out House 0 02-16-2006 02:12 PM
