Air compressor question - Kawasaki ZX-10R.net
post #1 of 9 Old 09-10-2010, 03:37 PM Thread Starter
NinjeR's Avatar
What's a good size air compressor to keep around in the garage? For the simple impact gun use, tires etc etc.
I found a good deal on a 2hp 8 gallons for 25 bucks. Not sure if that's too small or not.
NinjeR is offline
post #2 of 9 Old 09-10-2010, 04:01 PM
kabooki's Avatar
Too small. The tank isn't big enough to keep up with the impact. To fill a tire would be fine but running air tools it would be worthless.
http://viewer.zmags.com/publication/99a6ceeb
^Magazine my bike is in^
Facebook 465motorsports
Sponsors-Core Moto, Indy Ducati, 465 Motorsports, Seats By Tommy, Blingrockets, Sportbike Lights, Pro Kote Indy, True Finish, Indy Ducati.
Wrecked. Body mods; broken shoulder, #2-#12 ribs broken, 2 leg fractures, 2 broken teeth, broken wrist, road rash, 3 day coma.
kabooki is offline
post #3 of 9 Old 09-10-2010, 04:29 PM
Teeks's Avatar
If your just going to run an impact now and then, a 15 gallon type should do fine. If you going to use steady running air tools like a die grinder, sander, or something along that line then look for 30 gallons or more. I dont know if your in the market for something new at all, but if so check all the reviews you can. There are a LOT of crappy compressors out there. If you buy a lightly used one make sure ask the original owner if it was broken in properly. That is one of the most common mistakes that new owners make, is not reading the manual. Almost all compressors need to be ran for 10 to 30 minutes (depending on manufacturer)with the relief valve open for proper break in and piston ring seating. Many people dont and you will get a compressor with a really short life span.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #4 of 9 Old 09-10-2010, 04:56 PM
Sebastian1000's Avatar
8 gallon is tiny IMO.
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #5 of 9 Old 09-10-2010, 05:18 PM
BratNetwork's Avatar
IMHO even a 30gal is small for steady use of air tools. I have a 33 gal and mostly use it for blowing air and some impact gun, but I use a die grinder on occasion and had it regulated down to like 45psi doing a port and polish and I still had to take breaks here and there to wait for the pressure to build back up.
I don't use it often, but if I did use it more I'd prob go for a 60gal or something.
The key factor to look at is the CFM rating. The tank size will affect the CFM, but CFM is more important than tank size. A higher end compressor with a 60 gal tank will produce a higher CFM than a cheapo.
2008 ZX-10R | Black | Arrow Headers | AreaP Slip-on CF | K&N Filter |GUTS ECU Flash By Guhl Motors | Block-Off Plates | Fender Eliminator | Clear Alternatives Integrated Taillight | Rifleman's 1/5th Throttle Insert | Speedohealer | Pro-Grip 719s | Vortex Bar Ends | Puig Z DB Windscreen | CBR1000 Mirrors | Vortex 520 Sprockets -1/+1 | RK Gold 520 Chain | Galfer SS Lines | Pazzo Shorty Levers | Vortex Gas Cap | Rebuilt Damper | Lightech Rearsets | Much More To Come
BratNetwork is offline
post #6 of 9 Old 09-10-2010, 06:13 PM
Mladinracer's Avatar
Oh. Good to know. I was getting ready to buy one myself and never would have even thought of that. Thanks for the advice.
Mladinracer is offline
post #7 of 9 Old 09-10-2010, 10:05 PM
Teeks's Avatar
Brat i agree with you completely. I have a good quality 30 and when im doing a lot of grinding i have to take a break now and then as well. However im not doing it all that often, or i would have a 60 or so. Mine is on wheels and upright, so it still does not take a ton of space, and is movable if needed. I also didnt want one that uses 220, as i dont have a hookup for that where i live now (i rent).
Anyhow im babbling for no good reason, but yes i agree with you completely. I just didnt think anything more would be necessary for the OP's questions. Good looking out though.
Teeks is offline
post #8 of 9 Old 09-11-2010, 01:06 AM
nczx-10r's Avatar
I have a 6hp 30 gallon craftsman in the garage have had it almost 8 years, I have run a D.A. with but it works it pretty good, as far as impact and air ratchets not a problem.
ITS BETTER TO BE HATED FOR WHAT YOU ARE...
THAN LOVED FOR WHAT YOUR NOT..................
nczx-10r is offline
post #9 of 9 Old 09-11-2010, 09:44 AM
You could also just plumb another tank....it will take longer to fill of course but your pressure will drop slower as well. My father ran a setup like this for some time and it worked pretty good.
1997 600R Sold
1976 KZ 900 Sold
2006 DL 650 Sold
2004 ZX-10R
FS: Air compressor for air shifter cbolton69 Parts, Gear and Accessories 2 06-20-2010 08:52 PM
Air compressor and spray gun? edouble The Out House 15 03-20-2010 09:03 PM
Air Compressor... Bullshark The Out House 24 09-26-2006 08:30 AM
where do i put my compressor????? mikebar4 Race and Stunt 9 04-05-2006 12:09 PM
Air Compressor RickRoush03 The Out House 19 10-08-2005 02:03 PM
