About To Deploy - ?'s About Storage. - Kawasaki ZX-10R.net
post #1 of 9 Old 03-03-2007, 08:53 AM Thread Starter
zx10x2's Avatar
Images: 19
Send a message via Yahoo to zx10x2
I am about to deploy and need to make sure I am storing the bike right:
1. Change oil
2. Put on stands before leaving
2. Clean bike
4. Cover bike
5. Wifey will start it up about every 2 weeks and let it run for about 2-3 minutes or should I just this one and put it on a batery tender.
6. Amoural the tire real good J/K
I will be gone for 6 months.
Oh I forgot - Chain the bike down and secure it.
- 90 Mustang Coupe - 578 hp Grocery Getter
- 06 ZX-10 no mods - I love it
- 10 F250 Crew Cab
- 08 F-450 Crew Cab
I HAD A HANDLE ON LIFE, BUT IT BROKE OFF
zx10x2 is offline
post #2 of 9 Old 03-03-2007, 09:09 AM
McHaggis's Avatar
Thank you for your service.
"The key to immortality is first living a life worth remembering"-Bruce Lee
McHaggis is offline
post #3 of 9 Old 03-03-2007, 09:14 AM
05Zixxer's Avatar
Just put it on the tender. You can get a Battery Tender Junior for between $30 and $40 at Cycle Gear. I tried to have my wife start my bikes while I was gone but it's much easier to put them on a tender. Starting them for 3 mins wont do anything anyway. It's more harm than good.
Stay safe!
Kelly
'05 ZX-10R
05Zixxer is offline
post #4 of 9 Old 03-03-2007, 10:25 AM
lexusrx's Avatar
the day you decide to put her up go to the gas station and add stabil to the tank. fill the tank up and ride home. change the oil, hook up the battery tender, put her up on stands,cover her up.
if you have a front stand that attaches to the lower triple i would recommend pulling the front wheel. that will keep the front forks from being topped out for 6 months. i have not seen any proof that leaving the front wheel suspended for long periods of time hurts the front suspension but removing the front wheel will guarantee your suspension is good when you get back. if someone wants to steal the bike they will have to install the wheel first as well.
Retail is for squids. Shop like a pro at Superbike Supply.
[email protected]
https://www.facebook.com/superbikesupply
www.forum.superbikesupply.com
1-828-287-2101
lexusrx is offline
post #5 of 9 Old 03-03-2007, 10:33 AM
I bleed Green!
whispering smith's Avatar
Images: 21
When you get back dont forget about that armorall slicker then pig shiot.
God speed and you are in our family prayers.
Riseing Sun 2000 ZX-6R
Green 2004 ZX-6R 636
Every day is a new beginning.
www.stealeyconstruction.net
whispering smith is offline
post #6 of 9 Old 03-03-2007, 10:37 AM
SkyDork's Avatar
What has already been said is good advise.
Do not have the wife start it. It's better to sit for 6 months than being run for 2-3 minutes every 2 weeks.
A full fuel tank to prevent condensation, fuel stabilizer, and a battery tender is all you need. A cover will help keep her looking good as new until you get back.
#WordCrimes
SkyDork is offline
post #7 of 9 Old 03-03-2007, 10:54 AM
Post Whore
1. Change oil
2. Clean bike
4. Cover bike
where you heading too, im in the same boat, im heading to baghdad for 1 1/2 years... im probably just going to sell my bike good luck to you
Nick.INF is offline
post #8 of 9 Old 03-03-2007, 12:38 PM
Currently Clueless
Slims10R's Avatar
lube your chain also
Taking the WORLD over 1 Blonde at a time
Slims10R is offline
post #9 of 9 Old 03-03-2007, 02:26 PM
brian0128's Avatar
Don't forget to put saran wrap or plastic bags held down with rubber bands over the tail pipes to keep moisture and bugs out. Spray a little bit of wd-40 in as well. Not sure if your putting the bike in a temp controlled area, but after you do the final oil change, you can pull the plugs and put 25cc of oil in to coat the walls, rings, and valve seats. Some people rotate the crank by hand to get a coating inside on everything. Easier way is to put the bike in 4th and roll it forward. As was said above, keep the tires off of the ground to avoid flat spots.
brian0128 is offline
Gear storage? Tread70 The Out House 12 01-15-2007 10:23 AM
Put 10 in storage today Darren797 The ZX-10R 35 10-24-2006 06:27 AM
Question about storage lunitk The ZX-10R 39 01-19-2006 06:07 AM
My 05 10R out of storage. ZXMustang Pictures and Videos 15 01-15-2006 10:50 PM
Winter Storage YSR50 The ZX-10R 12 10-28-2004 03:01 PM
