2001 Raptor 660 - Kawasaki ZX-10R.net
post #1 of 4 Old 10-12-2006, 08:53 PM Thread Starter
I'm here WAY too much..
Bullshark's Avatar
2001 Raptor 660
Maybe some of you more experienced mechanics can help..
I have a '01 Raptor 660 that I just did the clutch on... I've never done one on a quad before, so I'm not sure if this is normal. I had trouble getting the pull rod to engage with the arm that connects the clutch cable to the case, so I took the screw out, pulled the arm out and finally got it to engage. My problem is that the clutch cable is at near max adjustment and its SO stiff=. It also seems to stay slightly engaged with the lever pulled in. I can put it in neutral and push it like it was nothing, i put it in gear, pull the clutch in and roll it, but it takes much more pushing to get it moving. Its easy to tell that its not completely disengaged. I cant start it b/c I still have the carbs, air box, and sub frame apart. Can I attribute the stiffness to the new springs? Am I missing something? Any suggestions appreciated..
Bullshark is offline
post #2 of 4 Old 10-12-2006, 09:13 PM
Send a message via AIM to Bigtuna660
I have an 04 Raptor, and while I have not yet replaced the clutch, I do know that my clutch stays partially engaged when pulled in. And when starting in gear, it lurches just a bit sometimes. I know this probably doesn't help, but if you go to ATVconnection.com and go to the Yamaha forum. Those guys know their stuff.
-Brandon
06 ZX-10R
04 Raptor 660
98 CR250
"A wise man never plays leapfrog with a unicorn."
Bigtuna660 is offline
post #3 of 4 Old 10-12-2006, 09:19 PM
Daves Cycles's Avatar
http://www.rochestermotorsports.com/...ion_detail.asp pull up the clutch page on this unit
You more than likely have the push rod(15) installed wrong.Take the cable off at the pivot arm on the engine.Rotate it till you feel the push rod has made contact with the pressure plate(toward the cable).Take the bolt out that holds the clutch arm from coming out.Pull the rod out rotate it back(away from cable)about a inch then drop it back in.
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
post #4 of 4 Old 10-12-2006, 09:33 PM
-Brandon
You might a worn clutch basket.The fingers in the basket get notched from the friction plates.There by not allowing them to release when you pull in the clutch lever.
Jaws Of Life On A F-22 Raptor !!!! oneradten The Out House 8 01-24-2007 06:59 PM
Raptor shift light help max-out Performance and Tech 9 09-16-2005 08:11 AM
Need help w/ Raptor Shift Light crispin Performance and Tech 18 05-25-2005 04:15 PM
How do I install a Raptor Shift Light? crispin Performance and Tech 18 05-05-2005 12:15 PM
2004 Yamaha Raptor for sale Krazy1 Parts, Gear and Accessories 7 06-30-2004 10:14 AM
