05 10r-HID dilemma - Kawasaki ZX-10R.net
post #1 of 20 Old 10-06-2011, 10:46 PM Thread Starter
1808a's Avatar
05 10r-HID dilemma
So i installed hid kit on my 10 earlier, in the process i had to drill a whole in
the light cover to get the cables thru,has anybody done the same process and
what have you use to cover the holes?? Another thing how can i level my
lights i found the little screw that turns but i dont know if it that what moves
the light any help please
1808a is offline
post #2 of 20 Old 10-06-2011, 11:15 PM
Shift_Nashville's Avatar
Yeah, its normal to have to drill a small.hole to feed the cables...
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #3 of 20 Old 10-06-2011, 11:45 PM
cyclepuck's Avatar
I had the dem kit and it came with a rubber grommet.
cyclepuck is offline
post #4 of 20 Old 10-07-2011, 07:25 AM Thread Starter
1808a's Avatar
the hard shit was trying to hook that pin in that hold the bulb in place, so do ya know how i can move the light is it that lil screw by the cover ??
1808a is offline
post #5 of 20 Old 10-07-2011, 08:21 AM
copperelite's Avatar
Send a message via Skype™ to copperelite
the turn nob down below moves left to right, and the gold 8mm/phillips screw moves them up and down. hope this helps....
copperelite is offline
post #6 of 20 Old 10-07-2011, 08:35 AM
evallarta1's Avatar
Yup had to drill a hole in the cap and then popped the grommet into place.
Velocity Calibrations
evallarta1 is offline
post #7 of 20 Old 10-07-2011, 09:12 AM
I had to drill a hole in the backing as well, but I had a rubber grommet that was included with the ballast and such. It was really a piece of cake getting the whole setup done. Hardest part was splitting the lens from the housing, but nothing a little heat couldn't fix.
Dropped some pictures for you... I don't have one of the cut-off line, sadly.
JArnold is offline
post #8 of 20 Old 10-07-2011, 10:53 AM Thread Starter
1808a's Avatar
Thanks for the help fellas i figure it out thanks to yall ill post some pics once i get home im hiding at work to be on the site
1808a is offline
post #9 of 20 Old 10-07-2011, 11:03 AM Thread Starter
1808a's Avatar
Hey bro where u got those little white markers i tried putting some red ones i got from autozone but only one works
1808a is offline
post #10 of 20 Old 10-07-2011, 11:14 AM
nfranke's Avatar
do you line the projectors JArnold, i thought about puttng thoose in
nfranke is offline
05 Dilemma----> TRE/PC3 ROACH The ZX-10R 4 02-27-2011 10:11 AM
Dilemma !!! mr_honez General Motorcycle Discussions 30 09-16-2009 08:19 AM
Stompgrip dilemma RedNinja The ZX-10R 10 02-10-2007 08:43 PM
Exhaust dilemma? Hattori Hanzo The ZX-10R 18 12-14-2006 10:00 AM
Dilemma-input please gpz1100 The Out House 17 11-14-2005 09:56 AM
