Gen 5: 2016- Woolich software update - Page 11 - Kawasaki ZX-10R.net
 28Likes
post #101 of 106 Old 08-29-2018, 03:39 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
What ever happened to these options that were available on the Gen4?
Retain Last Traction Control Setting (off specifically)
Change Traction Control Settings while riding (Change to off, while riding)
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #102 of 106 Old 08-29-2018, 04:02 PM
Formerly CLCRACINGAaron
Neonmarine's Avatar
Originally Posted by Vonstallin View Post
yeah..def have to have the throttle completely off...ive rode and dive bombed a turn and probably had full gas throttle OFF for a fraction of a second and it changed gears down, but i hit the throttle up some and it lurched me forward...
I ended up just turning it off. I did that like 1 out of 7 times id guess.
I was told by my motor shop to pull 2 of the 4 clutch slipper springs to reduce the lurching. They even said their rider was using 1 spring at some tracks to reduce the affect of engine braking. Apparently the slipper is too tight from Kawasaki and by removing half the springs it really helps soften the slip action and smooths out the blipper downshifting.
Still happens at low speeds and low gears. My Woolrich blip settings are money on the track where I truly care about it.
dudewhrsmybike likes this.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #103 of 106 Old 08-30-2018, 07:52 AM
This would be AWESOME to have... has anyone heard an update on if this is going to be a thing?
dudewhrsmybike and Neonmarine like this.
tjg312 is offline
post #104 of 106 Old 09-29-2018, 04:36 AM
Maniac_ZX10R's Avatar
Immobilizer deactivate
I already did another topic but maybe it also fits in here. Im Searching for a way to delete EU spec immobilizer since i want to get rid of my keys cause it is a race bike.
What bin file part numbers don't have immobilizer and would flashing one of them delete the immobilizer? Any other ideas how to get rid of it?
Thanks in advance, Roman
Maniac_ZX10R is offline
post #105 of 106 Old 02-03-2019, 09:51 AM
Originally Posted by ZX10RArcher View Post
Try the A model then. If you still don't have anything, then it is entirely possible the OEM sensor is defective and not working detecting shifts. Wouldn't be the first one we've seen.
Archer, are you shure we can flash A or B model on a C? I did but it seems i cannot enable QS down. Only the up arrow appears? Thanks in advance.
post #106 of 106 Old 02-09-2019, 11:15 PM
Hi Maniac, you can just use the Woodcraft key eliminator. It s just plug and play, and no more keys.
I use the ignition area for a GoPro mount now, to get all the dash info on video too
Safrican13 is offline
Is woolich right for me? ukzx10r Performance and Tech 5 09-11-2016 04:13 PM
Woolich tuning Bluey The ZX-10R 10 05-22-2015 01:04 AM
Dyno Chart - Woolich Racing Tuned software vs Stock ZX10R jkwool Performance and Tech 41 06-28-2013 05:22 PM
DynaJet QS software. Or PK shifter software. jblaze Performance and Tech 3 04-20-2009 09:02 PM
