Gen 4: 2011-2015 won't shift into second gear - Kawasaki ZX-10R.net
 3Likes
post #1 of 12 Old 09-27-2018, 10:13 AM Thread Starter
Post Whore
Older Guy's Avatar
I just picked up my bike from the shop - they installed a new chain.
Now it won't shift into second gear. And shifts are VERY hard.
I adjusted the clutch all the way and no change.
Suggestions?
Older Guy is offline
post #2 of 12 Old 09-27-2018, 11:10 AM
belkins's Avatar
Suggestions?
If they just installed a chain you may want to check the chain slack. Could be to tight causing the hard shifts. I would be taking it back to them.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #3 of 12 Old 09-27-2018, 11:14 AM
SkyDork's Avatar
Hey, OG.
So, they just replaced your chain? That's it? Nothing they were doing would really affect the transmission like the symptoms you're describing. They likely would be into the countershaft sprocket area which means removing the sprocket cover. To do that, it helps to remove the shift linkage and throw arm. Have you made sure that the throw arm is on there correctly and 90 degrees to the rod? Is the throw arm interfering with the cover at all? Posting pics might help.
Also, remember that the PNF prevents shifting to 2nd gear unless the rear wheel is spinning. I'm assuming that the problems related to shifting are when you're riding it and not with it sitting still on the stand.
GreenOne and dudewhrsmybike like this.
#WordCrimes
SkyDork is offline
post #4 of 12 Old 09-27-2018, 11:51 AM Thread Starter
Post Whore
Older Guy's Avatar
Originally Posted by SkyDork View Post
Hey, OG.
They replaced chain and sprockets. And just taking it from the shop, it wouldn't shift...so it had to do with what they did. I got home and put in on my rear stand and tried adjusting the clutch all the way and it still wouldn't shift into 2nd with the rear tire spinning.
post #5 of 12 Old 09-27-2018, 12:27 PM
SkyDork's Avatar
Yeah, I figured they did the sprockets also. That requires the countershaft sprocket to come off, but they wouldn't need to touch the clutch nor the transmission to do that. Have you had the chance to look at the shift linkage? Does it connect properly? What was the reason for not turning it around and going right back to the shop when you couldn't get it out of first?
#WordCrimes
SkyDork is offline
post #6 of 12 Old 09-27-2018, 12:31 PM Thread Starter
Post Whore
Older Guy's Avatar
Guy was backed up and it was close to closing time...I thought it was maybe just engine being cold but all the way home it was an issue.
I'll probably take it back today or Saturday morning.
post #7 of 12 Old 09-27-2018, 01:53 PM
SkyDork's Avatar
I get that. That's cool. But you should just check the linkage before you take it back. It could be as easy as a 2 min correction on that and you'd be back in business. Something externally is dragging and causing your issues.
#WordCrimes
SkyDork is offline
post #8 of 12 Old 09-27-2018, 10:55 PM Thread Starter
Post Whore
Older Guy's Avatar
I took it in and the tech was a bit defensive that he didn't touch the shift rod when he replaced the chain and sprockets. They tested and said, yeah, it's ain't right...they adjusted the shift rod and increased it's length and it works perfect now. Had no idea what it happened but it works...
The owner of the shop liked my Pazzo shorties...LOL
post #9 of 12 Old 09-28-2018, 08:51 AM
Capncalyx's Avatar
Id mark that place off my list. Was surprised what i could do with the cheap HF chain tool.
Chain n sprox is good beer drinking time. Or whiskey.
ddipaola likes this.
Live Til You Die - QOTSA
We will all die but only a select few of us will ever truly live.
We all will feed the worms and tree's so dont be shy
- QOTSA
Capncalyx is offline
post #10 of 12 Old 09-28-2018, 10:34 AM
ddipaola's Avatar
I have a feeling they didn't line up the indicators on the splines correctly - located on the change-shaft. One position off can really make a difference. I just recently did that to myself (installed 1 tooth out of alignment) and I had a hard time shifting like you. Make sure the indicator on your shift-rod pivot is aligned with the change-shaft one. They either A: reset the alignment correctly or B: adjusted your shift rod length and sent you on your way. Make sure they went with A.
When in doubt... send it!
ddipaola is offline
Gen 4 will not go into gear/won't catch 4th, 5th gear BigVee General Motorcycle Discussions 9 08-07-2015 12:42 AM
Gen 2: 06 zx10r won't shift into 2nd gear and up tmints Performance and Tech 4 08-27-2012 08:09 AM
Gen 3: ••••> My bike is dropping into neutral at high RMP's in second gear... Gun_Slinger The ZX-10R 14 08-23-2011 07:39 AM
Bike won't go into gear. Please help. JP636 Performance and Tech 20 09-03-2010 09:56 PM
difrence in 4 into 1 an 4 into 2 into 1 wnc rider Performance and Tech 5 06-27-2010 03:26 PM
