Gen 5: 2016- Where to install o2 wideband sensor - Kawasaki ZX-10R.net
 2Likes
post #1 of 22 Old 07-26-2016, 05:22 AM Thread Starter
FI-saki's Avatar
Hi Guys,
I'm asking your advice where to install wideband o2 sensor? I have stock header, Akrapovic titanium link pipe and slip on.
I marked few possible locations.
I've understood if I use wideband to narrowband adapter and mount o2 sensor to stock location, reading are not reliable?
I have also difficulties find welder who could successfully weld bung on thin titanium link pipe.
I saw there are "no weld o2 bung mounts" available. Are are these reliable? Lifetime / possible leakages?
Should I remove stock narrowband bung and weld wideband bung on stock location?
I would be very grateful for all recommendation / advices.
Thanks
FI-saki is offline
post #2 of 22 Old 07-26-2016, 10:32 AM
NixK7's Avatar
I'm in the same situation, the best way would be to remove the headers and get the 12mm narrrow band bung mad into a 18mm wideband, but pulling the headers is a pain in the arse.
So, i intend to get the 18mm bung i have, welded about halfway between points B & C on your picture.
NixK7 is offline
post #3 of 22 Old 07-26-2016, 01:06 PM
What!! Almost 1200$ of exhaust and doesn't even have a wideband bung? Anyway the best thing to do is weld a new bung to the link pipe in the B position. And rememder, Titanium pipe=Titanium bung, a steel one will not work fine.
Simon0721 is offline
post #4 of 22 Old 07-27-2016, 02:26 PM
Site Sponsor
chuckgraves's Avatar
If youd purchased a Graves exhaust the lambda receiver for the wide band is installed! Anyway Id locate it as anywhere from A to B.
Graves Motorsports Kawasaki ZX10r WORKS Cat Eliminator Exhaust
Chuck
GreenWeenie likes this.
chuckgraves is offline
post #5 of 22 Old 07-27-2016, 11:23 PM
how does the akra not have a wide band O2 mount in it the previous ones for 11-15 came with it
RBZ10R is offline
post #6 of 22 Old 07-28-2016, 04:04 AM
Unlike US, Euro models (and I belive AU models too) gen 4 came with O2 sensor, so the link pipe had the bung to install the stock sensor. Since on gen 5 the O2 sensor is in the headers, the link pipe bung is not more needed for normal operations. Considering the fact that many people install autotune or similars, a pre-installed wideband bung is a great move, that many manufactures did, but not Akrapovic.
post #7 of 22 Old 07-28-2016, 04:16 AM
Not adding an 18mm sensor bung in an aftermarket exhaust designed for sport bikes will surely narrow your prospective buying audience.
BOP Leader is offline
post #8 of 22 Old 07-28-2016, 04:41 PM
remove the headers, and adding 18mm narrow band
katdewy is offline
post #9 of 22 Old 07-30-2016, 07:45 PM Thread Starter
FI-saki's Avatar
I spoke with shop who does custom exhausts. They can't weld titanium but could easily copy titanium link pipe to stainless steel one with 18mm bung. If price reasonable I go with this option. Will see tomorrow.
FI-saki is offline
post #10 of 22 Old 08-02-2016, 08:55 AM
I know re the EU/AU spec bike, as I have a AU bike but it baffles me that an aftermarket link pipe wouldnt have a wide band bung.
RBZ10R is offline
Wideband O2 sensor location FI-saki The ZX-10R 0 07-26-2016 05:09 AM
Mounting wideband sensor? kkline_83 Performance and Tech 11 02-20-2011 10:49 AM
Who has a Dynojet Wideband sensor they will rent me? workin2hard The ZX-10R 6 08-01-2010 11:42 PM
o2 sensor install ryd2nrz Performance and Tech 1 03-31-2010 06:50 PM
wtb wideband pc and o2 sensor hesaves0211 Wanted: Buy or Trade 9 06-11-2008 09:21 PM
