Gen 1: 2004-2005 What maintenance should I be doing? - Kawasaki ZX-10R.net
post #1 of 5 Old 05-20-2019, 12:55 PM Thread Starter
I have an 04 10R and sad to say I haven't done much in terms of regular maintenance since I got the bike. I currently have 48,000km (30,000 miles) on it and I bought it at 20,000km (12,400 miles).
A side from the regular oil changes and clean/lube chain, I have replaced the brakes, changed the brake fluid once, adjusted my chain once and that's about it.
I've decided I want to keep this bike for a while longer so I wanted to get some work done to make sure it will continue running well.
What maintenance items should I be looking at doing? I for sure need to replace the air filter. Do valves need to be adjusted? should the plugs be replaced this early? anything else I need to be aware of?
Thanks a lot in advance!
2004 ZX-10R - Black
2003 ZX-6R - Silver
NightShark is offline
post #2 of 5 Old 05-20-2019, 02:03 PM
michael4012's Avatar
For sure the valve gaps want checking and no doubt with the mileage you have done will need adjusting. spark plugs and coolant-anti-freeze change for sure, air filter wheel bearings steering bearings swing arm bearings are things you can keep an eye on and change just when needed.
michael4012 is offline
post #3 of 5 Old 05-20-2019, 04:26 PM
Post Whore
Older Guy's Avatar
My gen 1 was never out of spec on the valves and I put 70,000 miles on it. Air cleaner pretty easy to do yourself on that bike. I've done 50,000 miles with original fluid in the radiator. no big deal.
Older Guy is offline
post #4 of 5 Old 05-21-2019, 10:03 AM Thread Starter
thanks for the info!
2004 ZX-10R - Black
2003 ZX-6R - Silver
post #5 of 5 Old 05-21-2019, 10:04 AM Thread Starter
anything else I should be looking at then?
2004 ZX-10R - Black
2003 ZX-6R - Silver
Should I or Should'nt I Falconrider General Motorcycle Discussions 39 03-02-2010 09:09 PM
Should I or should I not.. SOUN1 ZX-6R & ZX-6RR Archives 2 01-15-2009 03:03 PM
Should I or Should I not luckz88 The Out House 82 12-22-2006 04:28 PM
Annual Maintenance Ground Zero The ZX-10R 1 06-11-2005 07:57 PM
