Gen 5: 2016- What brake pads are you running and why? - Kawasaki ZX-10R.net
 7Likes
post #1 of 17 Old 10-06-2019, 06:20 PM Thread Starter
WILDWHISKEYWOLF's Avatar
Time for some new pads and want to know what everyone is running and why?
Sent from my iPhone using Tapatalk Pro
WILDWHISKEYWOLF is offline
post #2 of 17 Old 10-06-2019, 07:30 PM
Vesrah RJL on 2 bikes
RJL XX on track bike
GreenWeenie likes this.
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #3 of 17 Old 10-07-2019, 12:19 PM
Porschenut's Avatar
I use EBC HH pads because they're really easy on rotors. From what I've read they're great for street use but not good for track use.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #4 of 17 Old 10-07-2019, 01:04 PM
mpp12's Avatar
brembo stock and Vesrah, and EBC xtreme pro... only ones I trust.
mpp12 is offline
post #5 of 17 Old 10-07-2019, 03:48 PM
Post Whore
Older Guy's Avatar
EBC Extreme Pro
For the experienced rider that demands the best, the Extreme Pro Brake Pad by EBC gives the ultimate in motorcycle braking feel and power. Extensively tested for over a year, the sintered pads use the latest technology and composition to give no compromise in performance and wear.
Features a blend of tungsten and moly metal and were developed after comparing with 7 major competitors' products.
With vent groove to prevent backplate deflection and possible de-bond. EBC uses a wide molded vent groove dividing the pad compact into two separate pucks.
Pad de-bond can happen after corrosion gets under the edges of your pads, EBC has a unique way to prevent this by using non-corrosive elements in the pad matrix that do not interact with the steel backing plates and using its revolutionary double compact system, which prevents backplate flexion and edge lifting which leads to pad de-bond.
Super fast bed in, friction builds to a 0.6 rating after 10 - 15 stops in heavy use.
Perfect stability over EBC's 300 stop Daytona rig test.
Extremely low in-stop variation, compare this with the previous market leader pads.
Great heat cycling ability, you let the pads cool down after the ride and the next day, they repeat the previous perfect brake performance. In other words they heat cycle perfectly.
Now ECE R90 Approved.
Older Guy is offline
post #6 of 17 Old 10-08-2019, 01:32 PM
SkyDork's Avatar
Vesrah SRJL-17.
Why? Because Vesrah makes the best pads! Awesome stopping power, consistent feel, no noise, little dust.
#WordCrimes
SkyDork is offline
post #7 of 17 Old 10-08-2019, 01:47 PM
mpp12's Avatar
ebc extreme pro, the only cons is dust... vesrah and brembo produce less dust.
mpp12 is offline
post #8 of 17 Old 10-08-2019, 02:05 PM
Gen5, Stock Brembo pads, Club and Moto America racing. Great pads performance and life.
Lanister is offline
post #9 of 17 Old 10-08-2019, 03:09 PM
What's wrong with the brembo stock? Or why are the other brands better?
Guarf is offline
post #10 of 17 Old 10-08-2019, 03:25 PM
SkyDork's Avatar
There is nothing wrong with them. But they are a compromise between cost, mileage, and performance. That doesn't mean there aren't better options out there. Brakes are like suspension, it's about "feel" in most cases and inspiring confidence. I prefer to modulate the front lever with 2 fingers and I like the initial bite when the pads make contact. The stock pads are a good choice, but only if they meet your needs. I prefer the feel and performance of the Vesrah.
Here is a good read put together by another member here. This is LDH's experience and write-up, so credit where credit is due. But my personal experience is pretty much in line with his. I have run most of those myself with the exception of the Carbone Lorraine and the Performance Friction ones.
ROGUE RACING Brake Pads Review Page
I know most people talk about EBC, but after using their HH pads in the distant past I'll never touch anything made my them. They were that bad. I won't ever put them on my bikes again and I would rather put steel plates on the bottom of my boots and put my feet down to stop.
#WordCrimes
SkyDork is offline
