Gen 4: 2011-2015 Weird engine braking - Kawasaki ZX-10R.net
post #1 of 5 Old 09-06-2015, 12:26 AM Thread Starter
Formerly "bms"
BrandonZX10R's Avatar
Have a 15' ZX10R with about 13,800 miles on the bike. With an archer flash, motion pro quick throttle, -1 +2 gearing. Up until around 13k miles. When I downshift to engine brake into the corner or even to a stop. I get a sputter for a second or two and feel like I lose a little bit of engine brake, then it goes back to normal. Is this an issue? If so, any idea what it could be?
BrandonZX10R is offline
post #2 of 5 Old 09-06-2015, 12:29 AM
Chris99sleeve's Avatar
TCS on?
Chris99sleeve is offline
post #3 of 5 Old 09-06-2015, 12:33 AM Thread Starter
Formerly "bms"
Originally Posted by Chris99sleeve View Post
TCS on?
Yeah I keep it on but it does it when its off as well. I've never had an issue with it in the past.
post #4 of 5 Old 09-06-2015, 07:36 AM
SkyDork's Avatar
You're not Rev matching properly. It's the slipper clutch kicking in.
#WordCrimes
SkyDork is offline
post #5 of 5 Old 09-06-2015, 09:41 AM
White Fang's Avatar
If only it could be that simple; I remember feeling the slipper clutch kick in a few times when I first got my 30th Anniversary. It never kicked in once on my GSX-R 750, but the Gen 4 is a little more sensitive. The lever bounces, you can feel it very distinctly as a quick pulsation in the clutch lever. I have never noticed any anomaly with the engine. OP didn't mention a pulsation at the lever.
Once I got used to the clutch feel and adjusted it to my short little fingers it rarely recurred.
Seems that after 13,000 miles OP would have gotten the clutch thing figured out but who knows?
White Fang is offline
07 making weird noises and acting weird Z-Rider Performance and Tech 17 10-03-2013 09:15 PM
Gen 1: Weird:05 ZX10R Engine Limiting itself? jdmtunerguy The ZX-10R 13 11-08-2011 06:44 PM
2008 stock engine braking too hard on deceleration lizardfuel The ZX-10R 3 02-27-2009 01:47 AM
weird engine problems. holav Performance and Tech 5 09-05-2007 10:05 AM
Engine braking and popping....? 1bad10r Performance and Tech 17 03-16-2007 08:33 AM
