Gen 4: 2011-2015 Valve clearance check cost? - Kawasaki ZX-10R.net
 3Likes
  • 2 Post By SkyDork
  • 1 Post By gaz
post #1 of 10 Old 08-04-2018, 08:01 PM Thread Starter
Kawasexy's Avatar
2012 zx10r is at 16000miles, looking for average cost on a dealership or shop checking valve clearance? If I run my bike till end of season am I risking engine damage if I don't get it checked now? Or is their recommendation Overkill within reason?
Thanks!!!
Kawasexy is offline
post #2 of 10 Old 08-05-2018, 11:30 AM
97grnrs's Avatar
Gen 4 is more of a pain to adjust then any other gen. Shop probably easily charge 5/6 hrs labor or more. All mine were still in spec at 16500 when i checked
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #3 of 10 Old 08-05-2018, 02:43 PM Thread Starter
Kawasexy's Avatar
So are you saying I can wait another 3,000 miles and do it in the spring? Or do it asap?
Kawasexy is offline
post #4 of 10 Old 08-06-2018, 06:00 AM
97grnrs's Avatar
Every bike is different but I haven't seen many zx10 out of spec very far at 16k, if it's running and starts fine you should be ok
97grnrs is offline
post #5 of 10 Old 08-06-2018, 08:22 AM
SkyDork's Avatar
Maintenance schedules are there for a reason. And that reason is to verify that everything is working as it should. "Better safe than sorry" is the old adage. It will be mandatory on some bikes and useless on others. Unless you do the checking, you'll never know. The problem is there is no way to classify this based on what others get. It totally depends on how the bike is ridden, how it's maintained in other areas, and what the starting point was. They set a catch-all value against the maintenance schedule to cover everyone.
It's not one of those things that you should stop riding for and rush out to do. It's also not one of those things that should be neglected for another 5k miles or more. Look at your calendar to find some free time, make an appointment in the future that fits that, and just get it done when that fits in.
It will likely take a shop the better part of a day to do it. Most of that time is stripping the bike. You can shorten that by stripping down the bike yourself and taking it to them ready to check. Otherwise it's likely to be a $5-600 or more job (depending on what they charge for shop rates) and what else they find. Strip it down yourself and you can cut half the cost of that off if you talk to the shop about it and they'll work with you.
dudewhrsmybike and tbolt like this.
#WordCrimes
SkyDork is offline
post #6 of 10 Old 08-06-2018, 08:29 AM
gaz
run a simple 4 cyl compression test to determine cylinder psi and balance, will tell u what u need to know as far as performance and being safe.
SkyDork likes this.
gaz is offline
post #7 of 10 Old 08-06-2018, 01:46 PM Thread Starter
Kawasexy's Avatar
Originally Posted by SkyDork View Post
Maintenance schedules are there for a reason. And that reason is to verify that everything is working as it should. "Better safe than sorry" is the old adage. :-) It will be mandatory on some bikes and useless on others. Unless you do the checking, you'll never know. The problem is there is no way to classify this based on what others get. It totally depends on how the bike is ridden, how it's maintained in other areas, and what the starting point was. They set a catch-all value against the maintenance schedule to cover everyone.
Thank you sir for your informative response. I will definately get it checked soon but definately not scared to ride it for a little longer. Thanks again!
Thank you sir
Kawasexy is offline
post #8 of 10 Old 08-12-2018, 06:00 PM
The Pace
scout's Avatar
Call dealer for price.
scout is offline
post #9 of 10 Old 08-12-2018, 08:17 PM Thread Starter
Kawasexy's Avatar
Already did 350$ for checking another 100$ if needs adjusted...curious on what others charge
Sent from my SM-T377V using Tapatalk
Kawasexy is offline
post #10 of 10 Old 08-13-2018, 07:45 AM
Proteus's Avatar
Thank you sir
I would relax if I were you and get it done when you have the time on your schedule. In the meantime I wouldn't worry at all about engine damage by going over a bit.
The valves will typically tighten up a little (reduced clearance) over time due to valve seat regression and then stabilize. The first check is the most important for this reason but even if they are a little tight, it's not going to grenade your motor. The inspection schedule from the manufacture is very conservative IMHO to take into account the worst case scenario.
If you ran it way over and a valve or two tightened up excessively, the reduced clearance would hold a valve off it's seat and cause the loss of compression and hard starting symptoms mentioned earlier.
2016 ZX-10R KRT
2016 Ducati 959 Red
2015 CBR1000RR SP Repsol
2012 CBR1000RR Red
2011 ZX-10R Ebony
2009 ZX-6R Lime Green
2006 ZX-14 Passion Red
2004 VTX-1300C
"For we walk by faith and not by sight"
2 Corinthians 5-7
Proteus is offline
Feeler Gauge tool valve clearance check pic biglipps66 Performance and Tech 8 04-05-2011 08:24 PM
Valve Check Clearance Done muggz Performance and Tech 2 03-16-2011 04:43 PM
valve clearance job nobody Performance and Tech 45 05-30-2006 08:45 PM
valve clearance procedure nobody Performance and Tech 4 04-11-2006 08:36 AM
Valve Clearance hillcountry10r Performance and Tech 41 12-20-2005 08:18 PM
