Gen 5: 2016- TTX Preload Adjust Relocation - Kawasaki ZX-10R.net
post #1 of 8 Old 01-17-2019, 10:35 PM Thread Starter
ddipaola's Avatar
TTX Preload Adjuster Relocation
For those of you that have a TTX with the hydraulic preload adjuster, I found a good spot to mount the adjuster! Sorry in advance for the poor lighting, damn near midnight. Bought part number 03102-19 (adjuster clamp) for $50.97 from Ohlins, stripped the anodized coating, and removed a portion of the part to allow for more clearance/adjustability. Overall VERY happy. Now I don't have the eye sore of an adjuster just hanging off the side of the bike.
When in doubt... send it!
ddipaola is offline
post #2 of 8 Old 01-17-2019, 10:40 PM Thread Starter
ddipaola's Avatar
Showing the clearance between the inner swing-arm and the adjuster, approx 3mm.
ddipaola is offline
post #3 of 8 Old 01-17-2019, 10:43 PM Thread Starter
ddipaola's Avatar
And overall plenty of clearance to actually make adjustments. As long as you don't have oven mitts for hands and sausage fingers you'll be good
ddipaola is offline
post #4 of 8 Old 01-17-2019, 10:48 PM Thread Starter
ddipaola's Avatar
If you guy's predict any issues with this mounting location let me know. There could always be that one thing I overlooked that could create clearance issues or something... the more informed the better. Enjoy!
FYI if anyone needs a spring swap but you don't want to buy the tooling, aren't comfortable doing the work, or don't want to pay a hefty shop fee.. Throw me $25 (shipping on you) and I'll have it done the same day I receive it. I've done several spring swaps with no issues including this TTX one, and as you can see it's spotless.
ddipaola is offline
post #5 of 8 Old 01-18-2019, 03:47 PM
What is the adjuster clamp mounted to? I can't see in the pics.
Thanks-
2wheelmike is offline
post #6 of 8 Old 01-18-2019, 06:15 PM
Gen 5 Now!!
08zx10rny's Avatar
pretty sure the piggyback reservoir on the shock
Thanks-
GEN 5!!!
08zx10rny is offline
post #7 of 8 Old 02-07-2019, 04:33 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
I use to have mines located their.
I ended up making something for mines in a easier location.
Ill probably just buy the Ktech mounts for the Ohlins.
CCS/ASRA Novice 325 | WERA Novice 325 | The Nightmare of Summit Point
2016 ZX10R ABS | 2011 ZX10R | 2019 KTM 250XC-F
GunnRunnaz.com|Gunn Runnaz on FaceBook
Vonstallin is offline
post #8 of 8 Old 02-07-2019, 04:45 PM
Well done, man. Looks clean.
Lanister is offline
How to adjust rear shock preload on 2016? GearsNStuff Suspension and Tire Tech 15 04-21-2018 10:13 PM
Front preload adjust made-more tension on the chain? CTYrdr Suspension and Tire Tech 13 12-20-2013 02:11 AM
TTX preload setting Baddie Suspension and Tire Tech 1 01-09-2013 05:04 AM
Graves Motorsports - How To Adjust Motorcycle Shock Preload Gravesport.com Graves Motorsports 1 12-09-2012 01:14 PM
Graves Motorsports - How To Adjust Motorcycle Shock Preload Gravesport.com How To... 1 09-23-2011 02:17 PM
