Tire Warmers - Kawasaki ZX-10R.net
 13Likes
post #1 of 14 Old 07-17-2018, 12:27 PM Thread Starter
ddipaola's Avatar
Tire Warmers
What's everyone's opinions on tire warmers? Necessary, helpful, useless...
Running Q3+'s on the track. Can't complain about these tires out the box but I figured I'd get some references.
When in doubt... send it!
ddipaola is offline
post #2 of 14 Old 07-17-2018, 12:42 PM
I used to run the Q3+ on tracks with my 600 and no issues whatsoever without warmers. In my opinion warmers are useless with DOT tires for track days. One warmup/sighting lap won't kill you getting tire up to temp. The Q3's especially heat up quick as well. I would say save the money on warmer's unless running slicks or your going right into a race.
ddipaola likes this.
wheelz96 is offline
post #3 of 14 Old 07-17-2018, 12:45 PM
Last weekend I test D212 GP Pro 4 front and D212 GP Racer E rear. I don't have warmers, after 1st lap grip is ok, after 2nd drag the foot peg.
But this was track day. If is a race perhaps U must use warmers.
teror1sta is offline
post #4 of 14 Old 07-17-2018, 08:24 PM
Post Whore
Older Guy's Avatar
Q3+ don't need warmers...
Schooley and Neonmarine like this.
Older Guy is offline
post #5 of 14 Old 07-17-2018, 11:27 PM
R/T Performance's Avatar
you will actually over heat the tire if you run a full 20 minute session using warmers on a q3.
I run slicks and warmers are a huge pain in the ass but it makes them last longer.
Street tire operating temps are low setting on most warmers so your at operating temp when you go out and the just get over heated and greasy every lap you run which decrease tire life.
Neonmarine likes this.
2010 Zx10r Black spark Bazzaz zfi with QS,Puig Blue Double bubble,vortex rear sets,Blue Spools, fork sliders and oil fill cap,M4 street slayer,Penske triple clicker -1 +3 gearing 520 chain
R/T Performance is offline
post #6 of 14 Old 07-18-2018, 07:30 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
No need for warmers. Just check hot pressures (fresh off the track) 2-3 times throughout the day and rock on.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #7 of 14 Old 07-18-2018, 09:38 PM
evallarta1's Avatar
Can you use warmers on Q3/Q3+/Q4? Yes. Do you need them? Not necessarily.
Best case scenario you'll get some more confidence with less warmup laps. And you shouldn't overheat your Q3+s if you're pressures are correct.
Info straight from Dunlop. In the description they give you warmer psi and cold psi to start from.
Dunlop Racing » Q3+
Also, Dunlop recommends warmers for all tires be set at 158F for 45 to 60 min
Velocity Calibrations
evallarta1 is offline
post #8 of 14 Old 07-18-2018, 09:42 PM
evallarta1's Avatar
You have to be EXTREMELY careful with this process because it can be hard to control. The amount of time it takes you to come off the track, pit, and check pressures varies so widely from session to session its hard to get an accurate measurement. Thats why so many manufactures recommend off the warmer psi.
post #9 of 14 Old 07-18-2018, 10:17 PM
Post Whore
Older Guy's Avatar
31 psi front, 30 psi rear.....Q-3's are fine after 2 warm up laps...
Schooley likes this.
post #10 of 14 Old 07-19-2018, 06:40 AM
Schooley's Avatar
I usually only took it easy for 1 lap and never had an issue. 2 laps is probably much safer but I live in Texas so usually I am coming into the pits after the 4th lap
OP - Focus on hard acceleration and braking, without having to lean it & your street tires will heat up pretty quick.
wheelz96 likes this.
Schooley is offline
ChickenHawk Poleposition tire warmers INR1 Parts, Gear and Accessories 2 03-13-2005 01:19 AM
WTB: Tire Warmers jeffzx998 Wanted: Buy or Trade 0 03-07-2005 11:45 AM
Chickenhawk tire warmers for sale s4iscool Parts, Gear and Accessories 0 12-10-2004 09:35 AM
PD tire warmers SVTxtreme Parts, Gear and Accessories 0 08-01-2004 11:03 AM
tire warmers kwakman Parts, Gear and Accessories 3 06-29-2004 06:32 AM
