Gen 1: 2004-2005 Throttle stiffness - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Twist-IT
post #1 of 9 Old 08-16-2015, 09:39 PM Thread Starter
Twist-IT's Avatar
Throttle stiffness
Hey guys/gals.
my 05 throttle cables are stiff or seem to have resistance compared to pretty much any other bike I have tested. Off throttle to on throttle is jerky and I'm sure that is partially do to it being FI but still very jerky. Using silicone spray I have lubed the cables, routing is good, cleaned and lubed the TB springs and it still feels stiff. Bike has 20'000km and was poorly taken care of so just looking for some advice before I pull the throttle bodies for cleaning and replace the cables.
Thanks in advance.
Twist-IT is offline
post #2 of 9 Old 08-16-2015, 10:55 PM
TechX's Avatar
Check the throttle housing to see if it's binding. Sounds like you have checked everything else. It's probably ok but worth a look. Disconnect the cables from the housing and see if it rotates smoothly. You could also disconnect the cables from the throttle bodies and see if the cables are binding when you turn the throttle. If their not binding could be the throttle bodies are causing the issue.
TechX is offline
post #3 of 9 Old 08-17-2015, 12:07 AM Thread Starter
Twist-IT's Avatar
I removed the entire system and it all seems to work properly with no load, apply load and you can feel the drag and hear a slight grind. Its fairly smooth and returns normal but not nearly as smooth as I think it should be. Thanks for the reply.
TechX likes this.
Twist-IT is offline
post #4 of 9 Old 08-17-2015, 01:40 AM
TechX's Avatar
Like you said above bike was poorly maintained. The throttle bodies could need a good inspect and clean. Sadly
TechX is offline
post #5 of 9 Old 08-17-2015, 12:19 PM
zx racer's Avatar
To the op when you twist the throttle does it snap back?
05 ZX-10R SWB.
zx racer is offline
post #6 of 9 Old 08-20-2015, 06:38 PM Thread Starter
Twist-IT's Avatar
Yep, good and snappy return.
Twist-IT is offline
post #7 of 9 Old 08-20-2015, 07:22 PM
Porschenut's Avatar
Maybe your bike has a 1/5th turn throttle insert that you aren't aware of. I noticed that my throttle became stiffer after installing the insert.
Porschenut is offline
post #8 of 9 Old 08-20-2015, 10:51 PM Thread Starter
Twist-IT's Avatar
Good thinking... it is stock though so not the problem, Thx.
Twist-IT is offline
post #9 of 9 Old 02-22-2019, 03:54 AM
Unhappy
Did you ever find out what it was? i have the exact same problem and its doing my head in
ZX-10R D34N0 is offline
Gen 4: Pc 5 throttle position voltage full throttle ? abadassbikerlad The ZX-10R 3 09-09-2013 03:55 PM
1/5 throttle kit < 1/2 throttle Reddboy The ZX-10R 19 12-30-2011 02:19 AM
Throttle Cables, Remove Throttle Bodies? T_Bone The ZX-10R 8 07-09-2009 05:25 PM
Help, 1/5 rifleman throttle mod, throttle sticking! rainking12 Performance and Tech 11 05-10-2009 03:04 PM
Beware, heated grips + thin throttle tube = stuck throttle Drain Fade The ZX-10R 3 10-14-2007 02:34 PM
