Gen 5: 2016- Thinner kit head gasket - Kawasaki ZX-10R.net
 11Likes
post #1 of 12 Old 03-19-2019, 10:17 AM Thread Starter
kllrvet's Avatar
I have a 2016 ZX10r, and I'm thinking about installing a thinner race kit head gasket. Does anyone have experience with these?
I want to use one that is a drop in, as I don't want to be concerned with PTV clearance issues. they range from .50-.85mm, so there is a wide range to choose from. I honestly cant even find what the stock gasket thickness is.
Any help would be greatly appreciated
Thanks!
Tony
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
kllrvet is offline
post #2 of 12 Old 03-19-2019, 10:50 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
I'm going with what my shop recommended: 0.55mm
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #3 of 12 Old 03-19-2019, 12:34 PM
gaz
although ptv is diminished it's not the issue, piston to head is. measure deck height and adjust gasket to safe minimium.
gaz is offline
post #4 of 12 Old 03-19-2019, 01:00 PM
GreenWeenie's Avatar
without also adjusting cam timing, you likely wont be able to take advantage of the benefit.
Id talk to an engine builder before chancing screwing up a perfectly good motor.
Neonmarine likes this.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #5 of 12 Old 03-19-2019, 01:20 PM
Neonmarine's Avatar
Exactly right. Adding static compression without adjusting dynamic compression isn't good for power. You might not blow the motor with just doing the thin HG but you won't see much benefit without optimizing the stock cam overlap.
My bike is at KWS Motorsports getting this done right now.
post #6 of 12 Old 03-20-2019, 08:12 AM
gaz
static compression and running compession are directley linked, change one u change the other. there are hp/torque benefits to tightening squish with stk cam timing-engine building 101.
CanyonCarver likes this.
gaz is offline
post #7 of 12 Old 04-02-2019, 08:33 AM
Its not only the piston to valve clearance that you need to be concerned with. You also need enough clearance from the piston to head. Measure the squish, don't go any tighter than ,6 mm
bbsteinnewyork is offline
post #8 of 12 Old 04-02-2019, 03:09 PM
ShawnG's Avatar
Generally speaking yes, but with overhead cam engines you're shortening the distance from crank to cam center line so your timing is going to be off. Id bet you would loose power if you didn't degree them after installing a thinner gasket.
ShawnG is offline
post #9 of 12 Old 04-02-2019, 04:29 PM
gaz
no, u will not, cam timing change miniscule, i do this stuff all day every day.
gaz is offline
post #10 of 12 Old 04-04-2019, 05:08 PM
Carlos76's Avatar
No doubt, significant power gain is there if going from 0.85 to 0.55 gasket. 0.3mm change affects cam timing about one degree [0.3/(60xPi)x360x2]. Probably still no problem regarding ptv. But you really must check ptv anyway if doing this type of work.
bbsteinnewyork, gaz and Neonmarine like this.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
Race inlet and thinner head gasket browserzx10 Performance and Tech 12 04-23-2010 04:14 PM
porting+thinner head gasket mr wael Performance and Tech 73 11-02-2007 01:26 PM
Adding a thinner head gasket TKD-NINJA Performance and Tech 7 08-19-2005 10:03 AM
thinner head gasket spoon ZX-6R & ZX-6RR Archives 3 04-10-2005 10:29 PM
Thinner head gasket miykl The ZX-10R 14 08-23-2004 07:49 PM
