Suggestion for cleaning front brake light switch - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By Doppler
  • 1 Post By tdh
  • 1 Post By Bottoms-Up
post #1 of 9 Old 11-16-2018, 07:37 PM Thread Starter
Talking about the little switch that disengages when the front brake lever is pulled in. It seems to be sticking causing intermittent operation of my brake light. Rear brake operates the light fine, and both turn signals work.
I figure it just needs a little cleaning, and I'd prefer to not remove it if possible. Has anyone done this before? It's odd that it is failing so soon, this bike never sees bad weather.
GearsNStuff is offline
post #2 of 9 Old 11-17-2018, 04:07 AM
Doppler's Avatar
I'd go with Contact Cleaner. It's kind of like brake cleaner but for electronics and safe for plastics.
GearsNStuff likes this.
-Woolich/Race Tools/Log Box V3|-Graves Titanium/Carbon cat eliminator|-Ohlins Mechatronic|+2 rear|More stuff + stone chips & bugs
Doppler is offline
post #3 of 9 Old 11-17-2018, 09:12 AM
tdh
tdh's Avatar
I use contact cleaner as well but I will say it's not safe for "all" plastics. I sprayed some into my Chatterbox x2 helmet dock and it just instantly melted right apart. It must have been made out of some extremely crappy plastic.
tdh is offline
post #4 of 9 Old 11-17-2018, 08:37 PM
The Pace
scout's Avatar
Answer me this: do you leave your bike outside
scout is offline
post #5 of 9 Old 11-18-2018, 12:25 PM
badexample's Avatar
Scout! Answer me this: Do you do your maintenance scheduled oil changes?
ďRide like you are invisible.Ē
badexample is offline
post #6 of 9 Old 11-18-2018, 03:11 PM
Bottoms-Up's Avatar
I'd replace the switch, like $50
Bottoms-Up is offline
post #7 of 9 Old 11-19-2018, 12:06 AM Thread Starter
I have an aftermarket brake light/fender eliminator using OEM harness (didn't have to cut wires), so I'm not ruling that out, but the light's intensity and reaction time to applying the front brake will very intermittently. Doesn't matter if I slowly pull the front brake (disengage the switch), or quickly pull the front brake. Reminder the rear brake activates light perfectly, and turn signals work.
Wouldn't be the first time I've replaced that switch (on other bikes), just stunned how quickly it seems to have failed on this one.
For Scout, this bike is garaged. Maybe related to some over spray from cleaner/polish, although I doubt it, because it's not like I cake it all over the bike when cleaning.
post #8 of 9 Old 11-19-2018, 07:43 AM
ddipaola's Avatar
They make electrical conduct cleaner... $10 or so on Amazon.
When in doubt... send it!
ddipaola is offline
post #9 of 9 Old 11-20-2018, 01:27 AM Thread Starter
Thanks bro, I'll pick some up and give it a go. Have to say I was very happy that no one said to spray some wd/40.
My biggest concern is not the plastic, but the little rubber boot. If I have to I'll try opening the case and inspecting before purchasing a new switch.
Resolved: Suggestion {no 1 seems to read the suggestion section} Ergotomine ZX-10r.net Site Help, Suggestions and Questions 7 08-06-2013 09:53 PM
Gen 3: euro switch/headlight tail light off switch tc10 The ZX-10R 0 02-10-2013 10:12 PM
ZX-14 rear brake suggestion Black Stig Performance and Tech 3 08-16-2009 06:43 PM
