Gen 3: 2008-2010 Subthrottle Actuator - Kawasaki ZX-10R.net
post #1 of 5 Old 05-29-2019, 03:37 PM Thread Starter
Mine broke is that something that I can replace...manual says factory set... or do I need a new throttle body assembly or can the motor be ran with it unplugged.
Billy13 is offline
post #2 of 5 Old 05-30-2019, 11:21 AM
Kawasaki Brad's Avatar
Location: Stony Plain (West of Edmonton, Alberta, Canada)
Need a new tb assembly. Can't replace.
Engine won't run without it (or won't run worth a s#!t even if it does) because secondary butterflies are fully closed in their "off" position.
You can remove the flaps. Engine will run fine if they're gone completely. Will throw a code but won't limp mode.
Kawasaki Brad is offline
post #3 of 5 Old 05-30-2019, 11:46 AM Thread Starter
Is that the top butterflies or bottom butterflies? We run with our top ones closer to breather removed. But I did order a new TB last night.
Billy13 is offline
post #4 of 5 Old 05-31-2019, 11:58 AM
I was referring to the top butterflies.
post #5 of 5 Old 06-02-2019, 07:01 PM Thread Starter
We don't have top ones they where already removed. I have already recieved a new TB but will hold on to this one and try it later.
Billy13 is offline
