Strange Electrical Issue - Kawasaki ZX-10R.net
post #1 of 6 Old 01-29-2009, 09:44 AM Thread Starter
Jingalls1000's Avatar
Send a message via AIM to Jingalls1000
So I've finally got both me and the 10 healed up after my mishap at Jennings Gp last month (https://zx-10r.net/forum/showthread.p...87#post1112987). went out to ride it and found that while ride able, it still has two issues that went unseen during repairs. First the left clip on is bent down just enough that it hits the tank if i try and lock the steering. Thats an easy enough fix so im not concerned, but the next one has me out of ideas. When I go to change the brightness of the dashboard to dimmer for night riding the, the bike completely turns off. Not just the engine, everything electronically as well. To make things weirder, If i try this while the bike is in neutral or stopped, nothing happens. Obviously its something in the electrical systems, but where? I get mechanics, Im good at mechanics, but beyond splicing wires, electronics are a different world to me.
Any thoughts?
Why are we posting when we could be Riding?
Jingalls1000 is offline
post #2 of 6 Old 01-29-2009, 10:01 AM
inappropriate
hesaves0211's Avatar
Images: 67
perhaps your ecu is jacked and grounding out.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #3 of 6 Old 01-29-2009, 04:57 PM Thread Starter
Just tried looking at it. Removed the ecu and looked at every wire, nothing appears to be pinched or touching anything its not supposed to. What would i look for in the ECU itself? it doesn't have any visible abnormalities.
post #4 of 6 Old 01-29-2009, 05:02 PM
Bigprfed22's Avatar
Images: 93
lol the lighting doesnt go through the ecu... E-ngine C-ontrol U-nit, grab the wiring diagram and check it out, i dont have an 08 so i dont know about the dimmer. Check your fuses you could have one out. The switch itself was it through the crash? To dim you need a resistor that could also be out.
"Bs stops when the green flag drops"
Bigprfed22 is offline
post #5 of 6 Old 01-29-2009, 05:19 PM
06GreenMachine's Avatar
Send a message via AIM to 06GreenMachine Send a message via Skype™ to 06GreenMachine
I dont know much about these bikes yet but I do know cars so I do quite a bit or wiring diagnosis. There is deffinately a short to ground somewhere and it seems to be in the part of the harness close to your cluster and handle bars. I would start where the harnesses meet from the cluster and front controls. Check the fuses as well see if anything is blown. Time to trace some wires, good luck I hope this helps
06GreenMachine is offline
post #6 of 6 Old 01-29-2009, 05:41 PM
Bigprfed22's Avatar
Images: 93
If there was a short to ground dont you think the back light would be out in general as it receives no power? Dimmers work w/ a inline resistor. or am i mistaken?
ZX-10R '05 electrical issue Fillbiker Performance and Tech 7 04-17-2007 11:27 AM
Electrical Issue sonic397 Performance and Tech 8 09-16-2006 04:20 AM
Strange noise need help hangman39 Performance and Tech 12 03-28-2006 02:06 PM
This guy has a strange way of getting even! danno46 Pictures and Videos 12 01-09-2006 08:25 PM
Strange in here lately. legz10r The ZX-10R 33 09-25-2005 12:00 PM
