Started bike, Pop, Smoke! - Page 3 - Kawasaki ZX-10R.net
 3Likes
post #21 of 27 Old 04-21-2015, 02:30 PM
Capncalyx's Avatar
Originally Posted by Sid-ZX10R View Post
3rd real ride (twisties, canyons) on my new to me 07 ZX-10R. About a 100 plus miles into our ride we pull over over for scenic view stop. I start up bike after our break and a loud pop comes from front or under gas tank then a big poof of smoke. I immediately shut it off. We did an inspection and tried to pull off tank but previous owner had stripped 1 front tank bolt so we couldn't remove. Turned ignition and checked all lights, gauges, and started it up. It was running fine so we thought the carb had a backfire or something odd. We rode off slowly and about 1 mile down the road my friend pulls me over because she see's oil on my rear tire and smoke coming off bike. The bike sounded fine and rode fine before i shut it off but oil spewed all over rear tire and was smoking from oil leaking on lower exhaust. No oil coming out of pipes and can't see where the oil is coming from, but I will start tearing her apart tomorrow night. I seem to have lost less than a quart, but called AAA and had a great 2 hour ride back in a tow truck. My buddy thinks it could be the oil breather valve which doesn't seem too major? Any advice what to look for is greatly appreciated.
DAMN CARBS!! I'll never own another carb'd bike again! . SERIOUSLY!
Sid-ZX10R likes this.
Live Til You Die - QOTSA
We will all die but only a select few of us will ever truly live.
We all will feed the worms and tree's so dont be shy
- QOTSA
Capncalyx is offline
post #22 of 27 Old 04-21-2015, 03:01 PM Thread Starter
Sid-ZX10R's Avatar
Yes I had a 4 barrel holley put on last month!
Sid-ZX10R is offline
post #23 of 27 Old 04-17-2017, 08:27 PM
Hey so did you ever find the cause of the popped gasket I had the same thing happen and want to fix the issue before I replace the gasket? Thanks
waylinn09 is offline
post #24 of 27 Old 04-17-2017, 10:54 PM
blink.'s Avatar
It was just a wore out valve cover gasket, just replace yours and it will be fine.
https://www.zx-10r.net/forum/f23/f*-%24-what-118050.html an old thread about the same issue.
blink. is offline
post #25 of 27 Old 04-18-2017, 12:50 AM
So I shouldn't worry about what caused the pop/ backfire white smoke when I started it ?
post #26 of 27 Old 04-18-2017, 12:37 PM
blink.'s Avatar
Nah, should be good to go with a new gasket.
blink. is offline
post #27 of 27 Old 04-18-2017, 08:27 PM
Alright thanks just yo be safe I'm gonna drain my gas put fresh gas got a k&n filter doing the graves block off plates and new plugs also I'm gonna go ahead and leave the oil that leaked out. Out because I think I put a little to much last time I changed it. Also I got some engine ice to keep it cooler . hopefully it won't happen again.
Gen 3: PM me please--help me get the bike started without key(pic verify inside) streeteg The ZX-10R 6 04-27-2014 01:36 AM
Finally Bike Tatt Started Teeks The Out House 48 12-07-2013 05:09 PM
Bike started running rich suddenly bugman53 Performance and Tech 12 11-02-2007 10:56 AM
Riding and Bike started bogging? hale The ZX-10R 8 05-08-2006 07:29 AM
Wanna paint your bike? Heres a how to get you started! zx102nv Performance and Tech 11 05-26-2005 01:45 AM
