Speed - Kawasaki ZX-10R.net
post #1 of 8 Old 04-15-2019, 10:15 AM Thread Starter
Machining's Avatar
Speed
For you flashed guys, does your speedometer show your speed when you get above 186ish?
2016 zx10r
Throttlemeister machined throttle lock bar ends
Zero gravity corsa windscreen
TST integrated tail light
Techspec snakeskin grip pads
2 bros slip on s1r
Ecu flash coming soon
Radiator guard coming soon
Machining is offline
post #2 of 8 Old 04-15-2019, 01:50 PM
michael4012's Avatar
No the speedos stop but the bike will obviously keep accelerating, but when i am hitting 186 my gps is reading 174 real speed, which is give or take a few about the same on all, but unless you have altered the final drive ratios.
michael4012 is online now
post #3 of 8 Old 04-15-2019, 02:03 PM Thread Starter
Machining's Avatar
Thank you, that is a good point, I need to get a healer for the accuracy of the speedometer. Is there any known way to make the stock speedometer accurate and read out past the limited 186? Not that I plan on riding near max speed often anyway, just curious.
2016 zx10r
2 bros slip on s1r
post #4 of 8 Old 04-15-2019, 02:51 PM
No Bro they are that way because there top speed is supposed to be limited. Speedo healer is the way to go.
post #5 of 8 Old 04-15-2019, 03:00 PM Thread Starter
Machining's Avatar
Thank you, appreciate it.
2016 zx10r
2 bros slip on s1r
post #6 of 8 Old 04-15-2019, 07:28 PM Thread Starter
Machining's Avatar
Does heal tech make a speedo healer for a 2016? Don't see one.
2016 zx10r
2 bros slip on s1r
post #7 of 8 Old 04-17-2019, 05:12 PM
Doppler's Avatar
Just going back to your original question relating to flashing of the ECU, if I recall correctly the Woolich software for my Gen 4 has an option to correct the factory speedo error. Obviously this is not calibrated but it removes the built in 5% (or whatever it is) 'safety' buffer the bike has stock.
Also, altering the final drive ratios won't effect the speedo as takes its data from wheel speed sensor, as opposed to a pick up in the gearbox or crank angle sensor like older bikes.
-Woolich/Race Tools/Log Box V3|-Graves Titanium/Carbon cat eliminator|-Ohlins Mechatronic|+2 rear|More stuff + stone chips & bugs
Doppler is offline
post #8 of 8 Old 04-18-2019, 05:43 AM
Woolich flashing won't correct the speedo. If you reduce the front sprocket or increase the rear sprocket then the bike will be travelling slower than what it thinks it is if you increase front sprocket or reduce rear sprocket then the bike will be travelling faster than what it tjinks it is.
What speed has a cop clocked you over the speed limit? kapp241 General Motorcycle Discussions 127 05-28-2014 12:20 PM
Speed & Strength Speed Shop Boots ridersdiscount Riders Discount 0 08-08-2013 02:02 PM
Speed and Strength Speed Shop Leather Jacket ridersdiscount Riders Discount 1 06-26-2013 01:50 PM
Gen 4: SSB mag warp speed GEN 4 Top Speed Test bluedevil The ZX-10R 49 06-26-2011 04:51 PM
True speed and max speed (with GPS) mods2come The ZX-10R 23 05-22-2005 03:37 PM
