Shooting Flames - Kawasaki ZX-10R.net
 12Likes
post #1 of 13 Old 01-16-2019, 08:51 AM Thread Starter
ddipaola's Avatar
Shooting Flames
For informative reasons...
My AIS system is disabled but I still shoot flames (not complaining). Can someone explain why that is? What's the difference between disabling the AIS and removing it completely? Why does one setup prevent backfiring and the other still allows it?
When in doubt... send it!
ddipaola is offline
post #2 of 13 Old 01-16-2019, 09:30 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
During engine braking, most OTS flashes or profesional tuners will use a small amount of fuel to help reduce the affectiveness of engine braking. Often it isn't too much and flames are limited, but depending on what you need from the tune, it can be more.
Also, the throttle blades don't snap shut when you close the gas. The ETV will drop the TPS to about 5% and then slowly close the throttle based on preset numbers. Slower TPS closer, means a smoother engine brake affect. Add fuel during this moment and again the affect is reduced even more.
"You must subsume yourself to the bike"-Casey Stoner
"Thereís a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is offline
post #3 of 13 Old 01-16-2019, 10:53 AM
gaz
disabling pair valve with flash simpley stops the fi code u recieve if pair valve actuator is removed/unplugged. pair valve still operates normally injecting air into exhaust just as before flash. best/simplest solution leave valve plugged and plumbed, block off pair valve hose to airbox to stop air entering exhaust. that's the difference. must be done before any tuning whether dyno, auto tune to get accurate afr. there is residual fuel in exhaust on abrupt decel in any bike, with no oxygen present from pair valve or ex leaks goes unnoticed as in no popping/flames.
Kawasaki Brad and ddipaola like this.
gaz is offline
post #4 of 13 Old 01-16-2019, 11:19 AM Thread Starter
ddipaola's Avatar
Ah! Thank you. I was unaware that just the FI code is flashed out, not the actual function.
ddipaola is offline
post #5 of 13 Old 01-16-2019, 11:27 AM
gaz
google disabling pair valve vrs blocking it off, brock offers more info in video.
ddipaola likes this.
gaz is offline
post #6 of 13 Old 01-16-2019, 05:09 PM
GreenWeenie's Avatar
Yah,
take off the tank and airbox, remove the PAIR valve, and install block-off plates or plumb them together with a piece of hose.
Do the same for the intake flapper valve if you still have that too.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #7 of 13 Old 01-16-2019, 06:21 PM
Porschenut's Avatar
Or don't do any of that because you want wicked glorious flames!
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #8 of 13 Old 01-25-2019, 02:11 PM
Bikeman1000's Avatar
Images: 16
I DON'T agree that disabling the PAIR air valve only disables the code. . .WHY? Because I rode and tested it on my own bike. I replaced my exhaust, had it reflashed and tuned for exhaust but when the PAIR air was enabled it popped like a World Superbike and shot blue flames. It didn't like 35-50 mph around the city either. I have a You Tube video on it below.
Once I disabled the PAIR air, it drove much better in the city and at cruising speeds. It don't shoot the blue flames and much, much less popping. Just disabling the code will not just cause the bike to run better. That is why I believe checking the disable function HAS to be doing more!!! When it was enabled I never even had an engine code (I rode it like that an entire season). Check out both my You Tube videos and judge for yourself. I kept it disabled now. It runs better, just miss the World Superbike sound. I agree block off plates are a good idea but they are a pain in the ass. I haven't done mine yet.
Enabled PAIR air injection: https://youtu.be/dr4teRhBLV4
Disabled PAIR air injection: https://youtu.be/cc5-7TIXnrs
Bikeman1000 is offline
post #9 of 13 Old 01-25-2019, 05:56 PM
gaz
don guhl just answered this question coupe of days ago on zx14 forum, stated to his knowledge only his flash disabled code and pair valve function. may be a couple more, but most dont.
Bikeman1000 likes this.
gaz is offline
post #10 of 13 Old 01-28-2019, 06:23 AM
Images: 16
Woolich Racing software also disables the code and pair valve function.
flames or no flames? eskayeye The ZX-10R 58 05-06-2009 09:20 PM
Popping On Decel/Shooting Flames CurtZX Performance and Tech 31 05-17-2007 11:45 AM
Drive by shooting.I hope this is fake. sabersaw30 Adult Content - Photos / Videos - N.W.S. 17 05-23-2005 04:13 PM
Shooting Crap Up! DB's ZX10R The Out House 8 11-30-2004 04:41 PM
Video of US marine shooting wounded raghead camel fawker. R1GSXRKILLER Pictures and Videos 11 11-18-2004 07:25 AM
