Gen 1: 2004-2005 Shims - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Kawigreenguy
post #1 of 6 Old 10-15-2018, 05:37 PM Thread Starter
Kawigreenguy's Avatar
Shims
I need to throw a couple new shims in, after checking the valves. 2005 zx10r. Dealership says it HAS to ve kawi shims at $17 a piece. Thoughts?
Sent from my LG-H831 using Tapatalk
Kawigreenguy is offline
post #2 of 6 Old 10-15-2018, 06:54 PM
No, that's not true. All you need to purchase is 7.48mm flat shims (not sure what the imperial size is), which is a standard size and easy to purchase. And you shouldn't be paying $17 each!
RoninZX10R is offline
post #3 of 6 Old 10-15-2018, 07:16 PM
Porschenut's Avatar
I've done this job before and if you have the time to set the bike aside for a couple weeks, just buy batches of shims online in the approx. sizes that you need.
I used Hot Cams brand 7.48mm shims. You can find them cheap on ebay.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, JT (-1/+0), EK, Shorai, EBC HH, AllBallz roller steering, heated grips, shorty levers, MotoDynamic signals & relay, plasti-dipped and vinyl wrapped (all green to black), Bestem carbon, PUIG Pro sliders, solo cowl, modded sprocket cover, TST fender elim. w/LEDs. 50,000km+ and going strong!
Porschenut is offline
post #4 of 6 Old 10-15-2018, 09:18 PM
Bottoms-Up's Avatar
Pro X Valve Shims @ Rocky Mountain ATV
$1.99 each
https://www.rockymountainatvmc.com/p...o-X-Valve-Shim
Bottoms-Up is online now
post #5 of 6 Old 10-16-2018, 02:54 AM
GreenOne's Avatar
1. Can you swap around any shims so you need less new ones?
2. Check with a local shop if they will trade with your old. They re-use good shims on other customers bikes.
3. Buy new as already advised.
I`m just in for the ride
GreenOne is offline
post #6 of 6 Old 10-22-2018, 07:52 AM Thread Starter
Thanks for all the input. I ended up using shims from a shim kit that my buddy bought for his honda crf450. Same size shims..
sydwys likes this.
SHIMS SHIMS SHIMS!!! i need them mityaz Wanted: Buy or Trade 6 12-14-2009 05:08 PM
shims rocketracermike Performance and Tech 2 07-29-2007 06:11 AM
Pros / Cons of installing shims in rear shock fordfasterr Performance and Tech 9 01-29-2007 11:19 AM
Size shims for clutch springs? salsa1 Race and Stunt 3 05-10-2006 10:21 AM
Buckets, shims and a block head 1killer1liter Performance and Tech 18 04-11-2006 08:33 PM
