Gen 3: 2008-2010 shift shaft removal - Kawasaki ZX-10R.net
 4Likes
  • 2 Post By michael4012
  • 1 Post By Braaap21
post #1 of 7 Old 06-14-2018, 06:09 PM Thread Starter
shift shaft removal
so im in the process of trying to remove my shift shaft to the upgraded one. ive removed the bolt from the shift linkage and it seems like the shaft should pull straight out. i just want to see if theres any trick to doing this and if theres anything i should be aware before resorting to prying and tapping it out as its not coming out on its own. most likely is as simple as it seems, just want to verify so i dont want to break anything!
Braaap21 is offline
post #2 of 7 Old 06-15-2018, 12:33 AM
michael4012's Avatar
Gen3 you have obviously removed the clutch pack as your gonna be pulling from that side, well there is only the one circlip on the shaft that is on outside where you removed the single bolt on the linkage then it simply pulls out, try to use a new circlip when re-fitting as they do spread & weaken.
theatiss and Braaap21 like this.
michael4012 is offline
post #3 of 7 Old 06-15-2018, 02:01 AM Thread Starter
Thanks! Yeah I upgraded to a billet basket after seeing all the horror stories, so figure while I'm there replace the shift shaft as well. Completely overlooked that circlip, but she pulled right out afterwards
Braaap21 is offline
post #4 of 7 Old 06-20-2018, 12:01 AM
theatiss's Avatar
What brand is ur billlet clutch basket? Price?
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #5 of 7 Old 06-25-2018, 08:34 AM Thread Starter
I sent it off to hays machine works. Heard his was the best option in multiple forums. It's got like a 2-3 week turn around right now but I got it for 570$ shipped
theatiss likes this.
Braaap21 is offline
post #6 of 7 Old 06-26-2018, 12:09 AM
theatiss's Avatar
Have u seen any weight gains too?
theatiss is offline
post #7 of 7 Old 06-29-2018, 11:18 AM Thread Starter
Yeah, it weighs a little bit more but not much. It's worth the peace of mind knowing the basket wont blow up
Braaap21 is offline
Gen 3: Anyone have vortex longer shift shaft\tie rod zenga The ZX-10R 3 07-26-2016 05:48 PM
Gen 1: Secondary Shaft Removal?? NOSZX10R327 The ZX-10R 5 03-21-2013 10:48 AM
shift shaft/rod installation drob929 Performance and Tech 1 06-10-2007 10:59 AM
shift pedal removal? goducks Performance and Tech 9 11-28-2006 08:38 PM
